No, you only need to buy those if you want to improve high speed handling. The knuckles come with zero Ackerman arms.
Thank you, Harley. "thumbsup"
I've been looking for the 32p spur gears and I cant find who makes them
and says they fit the trans. Any info?
Thanks
I pulled the trigger and ordered the Wraith...it'll be here around the end of the month ,in the meantime I also put in an order to VP for Ti links, steering links, chubs , knuckles and lockouts as well as a set of wheels. By the time the truck actually arrives I think I'll have just about everything I need to bullet proof it right out of the box.
I also want to pick up overdrive gears for the front, MIP shafts and the dig unit when and if its ever released, Pitbull treads and the ZSS wheels from VP will make up the rolling stock. Eventually a big # Hitec servo will go in and Big Bore shocks as well.
I had to let go of a couple prized record albums to pull this off (org. mono Beatles albums) so I'm really hoping this thing is going to live up to its rep.
I'd also like to say thanks to Harley for all the info as well as his build thread"thumbsup" You've really helped to put me in the right direction with this thing
Started messing with my sons wraith this weekend to find a few issues with the transmission. First the pinion was not lined up correctly and the gears were not meshed well. This caused the pinion the chew on the spur gear and now it's really noisy. I want to replace the spur gear, with a metal one, and saw robinson racing has an 81t 48p spur gear. Would this work with the stock pinion and motor?
My Wraith hasn't even shipped yet and I've already spent more on upgrades than it cost, played around with my buddies 4pl last night and I just had to order one with a couple recievers to upgrade the fleet(of 2). I think I want to be the first kid in my neighborhood to have a Wraith with rear-steer.
We've been working on having a track built here, thanks taxpayers. Not that I'm expecting to be competitive against all the short course trucks that everyone seems to be ordering, but it should still be a fun alternative to crawling up the hills all the time.
The rear steer is a blast!
Do the AX10/SCX10 tranny gears fit the wraith tranny?
Do the Axial Trail Honcho Truck Body with Molded Rear Cage fit the Axial wraith?
Ok, just looked at them, I take it that one set of hole will line up, Right.
They only go up tp 54?
I was talking about the MMP SCT version with the 1415 2400kV motor :twisted: I had bought it to put into a FOFF rig, but I've ditched that project for now. Think its overkill? Should I stick with a Sidewinder-based ESC system?
Finally got mine! I took it out for a spin last night. I have to say that the motor seems lackluster. on 2S I was expecting more ummph out of a 20t. Hell I think my XR might be faster on its 35turns. Does axial detune them from the factory or something? I was thinking about hooking to castle link to it to look at the throttle curves...if I could figure out how to get to the ESC.
The gearing is mostly the reason it feels that way. It still needs to have enough low end grunt to be capable. Thats why the 20t on 2s doesn't feel like you might expect it to in some other car I believe. PLugging it into the Castle Link is probably a good idea though to make sure all the settings are where you want them.
