jopes
Electronics
Battery:
The Wraith has a very large battery box located in the rear of the truck. This box was built around a standard “stick pack” sized battery. The stock electronics run best on 2 cell (2c) LiPo or 6 cell NiMH, I suggest staying with LiPo. I have run the stock electronics with 3 cell (3s) LiPo batteries and the ESC and motor do just fine however adding an external BEC will be a must do mod if you plan to run with 3s. Be aware that running 3s will shorten the life span of your stock motor.
I plan later jumping on to Lipo's but for now it is cheaper packs till the electronics get upgraded.
I was going to pick up a couple 5000 7.2v nimh from hobbypartz as well as a couple servos for steering, but the 7.2's are back ordered.
If I grab something higher I am guessing it will work since some others have ran up to 3s on the stock electronics with a BEC.
If I went to 8.4v would a BEC be needed right away if I stay with the stock axial servo or will it cook it?
