jcboof
Chris, You now have 2 less 3S 1000MaH Lipos in stock. And a couple feet less of shrink tubing! "thumbsup"
I feel information like this should be known.
I just placed my order for 3 of the 850's to replace mine currents. Thanks for helping me get my head around the trickery and the magic that is building these packs.
Also super cool you presolder connectors and balance taps.
There are high end packs that aren't performing nearly close to their C ratings. And trust me. I wish my boss would let me disclose the brands tested. Although most can read between the lines. I feel information like this should be known.
It isn't hard to tell;-)
Also how exactly is the 'C' rating defined? I take it as my battery can put out X times the capacity without getting hot and then Y times the capacity without going into thermal runaway. Is that what I should be reading or should I be reading something like the c rating of voltage drop vs amps drawn is the dilation factor in a tangent graph?
Thanks"thumbsup"
Kieren
What if we can't read german?
Later EddieO
Chris_The_Battery_Man;2669338 [CENTER said:We discharged all the packs(or cells rather) under the same conditions. We applied a constant load and recorded voltage over MAH. This showed us how high the voltage was under load and how much MAH the pack delivered at a 3v cutoff. This is similar to the industry standard for testing lipos. We started testing at 20C (well below the max ratings of all the cells) and we were shocked to see the known brands did not perform well even at a fraction of their labeled C rating. [/CENTER]
I would like to play devil's advocate :evil:
According to your graph's, your batteries don't meet their claimed "C" rating either. Although your packs do appear leaps and bounds above the competition, do you plan on changing your labels of 35C to what your actually getting according to the graph's you posted?
For example:
Elite 1300 35C should be able to do 45.5 amps....your test shows 26amps?
Although you come closer to the claimed "C" ratings, we are still not getting whats on the labels.
He who has the least amount of trickery gets our money?
I am not arguing or bashing here. Just like you. hate seeing people waste their hard earned green. I'll probably order a few sets from you myself. "thumbsup"
Brian
His graph was a 20c load, so 20c*1.3mah=26amps. His batteries were right on target"thumbsup"
