Sammy J.
As long as you don't open the packaging and pay the shipping I would think they would exchange it for you.
Nice ^^^
Update - HH is of course being very cool and allowing the motor swap. I'm getting a HH 2700kv PP 540 soon.
Wish I had that feature on my sidewinder 8thI run a Mamba monster x and Holmes hobbies 3500 puller pro.
I have the 2 speed so it's nice with the monster x to be able to turn drag brake on for crawling in low speed and off for high speed runs.
anyone else have experience with the tekin roc412 series? Looking into first hand experience prior to pulling the trigger
I had issues with a motor cogging and it turns out that I had cheat timing turned on in my MMP and it went smooth after I turned that off. Just a thoughtI have the Castle MMX and the Tekin ROC412 3100kV on stock gearing. I mostly run it on 2S, but also on 3S when I want speed.
Something is defective though because I'm having a ton of cogging. I'm in talks with Castle because I think I ruled out the Tekin motor by testing another brushless motor. To be continued...
Thank you. I tried changing startup power punch and timing to no avail. What are your settings?I had issues with a motor cogging and it turns out that I had cheat timing turned on in my MMP and it went smooth after I turned that off. Just a thought
If you want, just reset to default setup and if that fixes it then tweak from there. CHEAT is not a default setup and this should get you really close..Thank you. I tried changing startup power punch and timing to no avail. What are your settings?
Castle did say I shouldn't have to change any software setting to get rid of cogging though.
No, default doesn't fix the cogging. What's "CHEAT"?If you want, just reset to default setup and if that fixes it then tweak from there. CHEAT is not a default setup and this should get you really close..
