...because it's the same as one of the cheap servos in this thread?
:lmao:
Do you mean the JX ones? to be totally honest this thread is way too long to read lol.
:lmao:
Generally speaking, titanium is a harder metal than aluminum and is nearly as hard as heat-treated alloy steels.
Our servos are advertised "dynamic" torque. Not static torque from a fish scale. As was pointed out in the video. I am very surprised they were that high on pure static. Definitely something to be excited about.
I've been thinking about my earlier comment about high-pressure grease. It was mostly made in jest, but I'm thinking that could be a thing. Similar problems result if you use the wrong grease in an automotive axle/bearing or oil in a diff/transmission.
I'd recommend people with 46kg JX's clean the stock goo off any try some good synthetic H-P or moly grease (not lithium grease).
I hate to really nitpick but too many people repeat this incorrect info. It bugs me to death.
Titanium is only good when it comes to weight or reactivity. It can be about as strong as steel but lighter, 5% weaker & 45% lighter for typical alloys. If the size of the part is unrestricted, aluminum/magnesium/beryllium can all be lighter & stronger. For a gear where dimensions will be the same & high-performance alloys of both are used, the steel will ALWAYS be stronger - and more ductile, shock resistant, wear resistant, harder, etc. Even so, Inconel makes them ALL look silly. But I digress.
Do you mind explaining this "dynamic" torque, because my BS meter appears to be pegged. Your webpage literally says "Stall Torque (11.1v): 527oz". Stall torque is defined literally as "the torque produced by a mechanical device whose output rotational speed is zero". In the vid at 12v it shows 484.9oz using the outside hole on that arm (1" from shaft centerline) at 90 degrees when it stalls, or 8% short.
For reference, the same test jig recorded 550oz/in for the Turnigy 959v1 at 5.7v & 498oz/in for the v2 while the G13 needed 15.8v to hit 566.7oz/in. The Achilles heel of the cheap servos seem to be the gears, so I really hope to never hear of a G13 gear failure - or at the very least zero-hassle repairs of any gear probs.
That seems to spit in the face of the fact that motors have optimal operating temperatures, because it isn’t as simple as cool == better...
So when you say "dynamic torque", you mean the amount of torque the servo can transmit while the motor/gears/hub are rotating? I guess that's good to know, but why would it be different from the amount of torque the servo can transmit when stalled? The servo is powered by an electric motor, so the torque should be the same regardless of whether the motor is able to rotate or not.
Dynamic torque is measured with a digital device that clamps to the top of the servo. It is very accurate and is often used on rotational loads. It calculates the peak torque with speed that the servo produces.
Bummer...looks like the Promodelers are on b/o for awhile. Just because I decided to get one. :roll:
This article seems to explain it, but it's flat-out stating that dynamic torque is different from static torque. The best description they use is measuring a multi-cyl IC engine at the crankshaft vs measuring at the wheels. Static torque is the average torque seen at the wheels while dynamic is the peak for each combustion event, usually called peak instantaneous torque. A Honda 2.4L will actually have a higher instantaneous torque than a Ferrari 3.6L v8, but we know which has more HP. Just recently SAE engine ratings have changed to reflect what's actually happening. In the 60's they used SAE Gross, which was with no accessories, no water pump, no flywheel - which lead to "gross" differences.
https://www.eetimes.com/document.asp?doc_id=1273988
In any case, your website only lists stall torque. It's also pointless to tell us dynamic torque but not stall torque when every other MFG does the opposite. Imagine if Ford measured how much force it takes to rip off the trailer hitch, then listed that as "tow rating".
I understand everything can break, but for 3-4 times the price I'd expect 3-4x less broken gears or replacements that are 3-4x cheaper. $18 for a gearset is 1/3 the price of an entire JX servo.
All right, I have a G13 on pre order for the Bomber...let's see whatcha got
Sent from my SM-G930R4 using Tapatalk
Will do. It'll be replacing a DS3218 so I would expect a rather noticeable difference in performance if it lives up to spec.let us know how it pans out!
I ordered a ds3218 for $12.75 shipped from ebay this evening. That 15% off coupon was enough for me to stray from my equally cheap go-to mg958, mostly because it will be here in a few days, instead of a few weeks as when shipped from China. This will be replacing a Traxxas 2075 on a Slash with 2.2 Ripsaws, so more than doubling the torque, and a few hundredths of a second faster will both be appreciated.
You have a 2075 that hasnt burnt itself out yet? Lucky dog! Every 2075 ive had blew its fuse during normal 2s SCT use. 4 for 4.
