MattySlimz1987
Now the Yeah Racing’s and PowerHD 20kgs are probably identical, but thankyou @Hydrocarbon92 for pointing out that the JX’s are different from PowerHDs.
Hmm... any chance the endpoints weren't set?The 6221 I had was in a stock bomber. I only ever ran it inside on a course I made of sofas and boxes. It did take a few falls from that but nothing major.
I was powering off a trackstar esc it was at around 6v I think. Not sure if underpowering a servo would result in higher amp draws and in turn damaging servo but when I swapped in the powerhd it was very glitchy and inconsistent on that same esc until I swapped in the castle bec set at 6.6v.
I did give in and ordered a castle x system to compare to the trackstar setup so I will be able to eliminate my bec.
Sorry that happened.I had em setup. Just unlucky I suppose
You can do that with pretty much any switching UBEC. In fact, for less money, you can buy adjustable buck converters that come with a pot instead of a fixed resistor.I'm planning on running it a little lower than max too. I just have a feeling the gears will be the weak spot, judging from the failure of most expensive servos.
Another JX I'll be trying is the 6208. It's $11 and internally seems to be a 6221 but with less gear reduction. It's as fast as the 5932 but obviously less power than a 6221, but I plan to use it for light on-road cars. Definitely the fastest $11 servo I've seen.
Also I figured out how to hack the voltage on a Hobbywing 3A UBEC. When you remove the metal cap, there are 3 resistors in a column above the 8-pin chip (pin header is to the left). The top resistor should be 39k. If you replace that with a 47k resistor, your new outputs are 6.1v and 7.0v. If you add a 10k pot in series (49k), the new voltages are 6.3v and 7.2v.
The LED might burn out eventually with higher voltage modification but who cares. The chip used is a MP1593, similar to the chips I posted about much earlier.
Exactly. I've had it happen with more expensive servos too. And this didnt feel nearly as bad.
I got the 5932 in and this servo is freaking sweet. I set it at 7.5v. It's fast strong and quiet. We will see how long it does. I also installed a mamba x so the bec was removed.
You can do that with pretty much any switching UBEC. In fact, for less money, you can buy adjustable buck converters that come with a pot instead of a fixed resistor.![]()
Stumbled upon this while searching on Banggood:
https://www.banggood.com/JX-BLS-12V...-p-1180609.html?rmmds=search&cur_warehouse=CN
That's pretty cool. Even cooler is the coreless is $10 cheaper at gearbest. An aliexpress page showed a couple of 5-star ratings from buyers.
Next candidate for testing: JX CLS5830HV
Motor: Coreless
Operating Speed 6.0V: 0.11 sec/60°
Operating Speed 8.4V: 0.09 sec/60°
Stall Torque 6.0V: 24.7 kg.cm (343 oz-in)
Stall Torque 8.4V: 30.3 kg.cm (420 oz-in)
Waterproof
Between $34-$38 various locations...
