DeeJay73
Those reservoirs look spot on with fluids and all. Did you pour paint into them or whats the method?
They are actual reservoirs holding fluid. [emoji12]
Are you Printing with filament or resin?
I'm guessing he paused the print, added colored water, and then resumed the print.
Not at all. I designed actual coolant and washer tanks with lids, just like the full size version.
I’ve been working on this for some time and have made many different iterations. I think I’m finally happy with how this has turned out. All designed by me in Onshape, using Simplify3d on a Wanhao i3+.
Jeep XJ 4.0L with single speed trans and transfer case.
That's awesome! "thumbsup" Does it hold a 540 motor inside?
That is pretty sweet, what gears do you have in it? Do you have any plans on sharing the files?
Has anyone printed a front mounted servo mount for the SCX10 ii? I bought a metal one before getting my 3d printer, and the ones from thingiverse don't seem to be anywhere close to the design that I know works - still looking for an STL file that works.
This is the metal one I use on my other scx10 and it works really well.What is the design that works?
The recent file I used (the link I provided) is a good one, but I still have to adjust things to get better geometry. The other files I found were a totally different design or had no bumper mounting holes [emoji848]Dosen't look that different to me. Perhaps it's the height the servo is mounted. You may be able to mirror that print to correct the servos mounting location if that's the problem.
I’m working on a new CMS/bumper mounting bracket. My motor takes up all the original servo/battery room.
I solved that problem with mine.
That is nice. Your motor looks super real! Is that a 3D print?
