What’s a recommended 3D printer that doesn’t break the bank?
The Ender 3 can be had for less than $200.
Finished the Coke machine...
Sent from my SM-G970U using Tapatalk
Thank you. Already have an idea in mind for my next vintage scale item....Beautiful work. Kind of makes me want to go dig into the past for things to model and print out when I get my printer.
None, YET!!
Test print running now. Fingers crossed.
Nice! Congrats. Which printer did you get?
Ender 3 Pro.
Printed some tail light buckets for my 10.2 Cherokee body.
Have an issue with bubbles under the magnetic sticker on the print bed though :evil: Also working out some warping/adhesion issues. The dog test print worked fine but, the buckets took a couple tries and I still had some warping. Luckily they won't be visible.
pla +
I've never used PLA+ so I really can't help you too much.
I use PLA+ or Pro. They have a bit higher hot end temp (215/55) I do a slow first three layers to get good adhesion. Then speed up a little. No cooling fan. With regular PLA I typically do 190/55. I feel like PLA+ is slightly stronger. In my experience the first layers are critical. I also use a .172-.2mm feeler gauge to set my print head. Hope that helps.
I've been printing this cab over the last few months and will most likely follow on with the bed later. Depends on how I use it. Probably more on this later to come....
1.2mm layer height, IC3D ABS, Sovol SV01
Sent from my HTC U11 using Tapatalk
Thanks. Yesterday was milestone getting the grill to print without failing. I've had to implement varied printing strategies from adding rigid supports in the slicer to pulling the stl in CAD and adding supports in key places. The hood was by far the most difficult. The secret was adding heat source in key locations.nice! "thumbsup"
So far, I have done, some inner fender liners and started on an interior (dash, front and rear seats). Also did some tail light buckets. Got the files to do a Tacoma body but, want to work out printer settings a bit more before I start on it.
What do you mean by adding heat source in key locations?
