What is your Crawler Stand? What do you use?
For my Losi MRC, I use the bottom 3" of two water bottles turned upside down; they look fine painted black inside and out, and are totally expendable (throw 'em around).
I use empty I lb. plastic coffee cans, also makes a handy storage bin with a lid, for parts, battery packs ect.
Here's mine. made it at work.
I just took a piece of plastic from the scrap ben at Tap Plastics and bent into a stand, put some rubber strips on top so it doesn't slid all over the place.
Another angle
Those ideas look awsome i have been removing wheels and usuing smaal books under the chassis skiplate. I seen the hudy stands which aside from shock holes look minimal compared to all of these pics
i use beer cans ;-)
hopefully those are empty!!!! just joined, i got a nitro savage 25, and i built a stand using 2x4's sandwiched together with 1/4" plywood on each side.. its perfect.. i dont have a crawler.....yet!!! seriously thinking about getting an ax10 scorpion..
I take off the wheels when not in use. It doesn't take long, then I store the rig on two hooks by the front axle on my pegboard. If Im working on it, I disassemble it all the way, if I need to work on an axle, I remove it, I hate trying to work on it when its all attached and sitting on a stand.
2" PVC or ABS pipe cut long enough to keep wheels and suspension off the shelf. I also use the small jackstands that they sold at northern but only for projects that have no wheels
I use a box to sit under the skidplate, keeps the tires off the ground and the weight off my shocks/springs;)
Some of you use some nice stands. I really like the PVC idea.
When working on it, like in this pic I use WK tires.
for storage I get them up outa the way. ;-)
