jason said:Everyone know the problem with clods is when your front or rear tires have more traction, the dual motors act like an open diff and the axle with the least traction spins freely. Sometimes this is an advantage, to me most of the time it is a hinderance. I spent a whole day changing setups, and tried to fix the problem, but anything I did didn't make a differecne. Has anyone figured out how to solve this problem?
Here's what I've tried.
1. Motors wired in parallel. Problem still exists.
2. Run dual superroosters, with one battery. Problem still exists.
3. Run dual superroosters, with dual batteries. Problem still exists.
None of these options even made a noticable difference, they all had the same results. I'm guessing it's just something we have to live with.
Jason said:We were all noobs at one time
kevinlongisland said:Woo HOO, finally a MAXX crawler forum!!!!!!!!!!!!!!!!!!
jason said:Just took my new max for a test, and the steering servo are hotter than hell. I've never noticed servos getting hot. Is this normal, whats causing it?
I used 1/4 scale servos, and they each run on their own battery.
DirkDigler said:My Kongs are going to be THE tire. Like you said Jason, tall and skinny. I just hope they are not too tall. 8+ inches and I will narrow them to about 2.5 inches. Tread pattern will be cut like my BFT's and I am thinking that there will be nothing better when they're done!!! We'll see by the end of the week.
roktoy said:I have been adding some RTV Silicone inside my servo savers to take up some of the spring "air space". Seems to help increase the overall spring rate a bit.
Jay
jason said:To help save bandwidth, in the near future I will be changing the file size limit for Avatars from 20,000 bytes to 10,000 bytes. If yours is over 10,000 it will soon be missing, so start looking for something new.
As of today this will only effect 14 people, and about half of those could keep the same avatar if they just compressed it a little.
Thanks
Jason
kevinlongisland said:i'm un-employed, so anytime you want to crawl let me know. email kevinlongisland@yahoo.com
kevinlongisland said:oops, forgot to sign in.
i've been installing my suspension mods on a stock widemaxx to see how well just the suspension mods work. The "stock" widemaxx only has locked diffs and lower gearing. that's about it.
kevinlongisland said:how do you like the twin force? anything on it look like it would be well suited for crawling? (axles, tranny?????)
DirkDigler said:Looks like Duratrax is coming out with the Warhead. Another wannabe!
Good news is that we now have another truck to rape parts from to build crawlers. The tires look like they have potential and I hear they are 7 inches tall.
jason said:We are working to make this the best RC Crawling site on the web.
Yeah right!?:roll:
DirkDigler said:rbgerrish:
"Oh, I forgot to mention that using 2.2" wheels and tires on TF axles would be similar scale-wise to running go-kart tires on a Dana 60! The axle would get hung up on everything. You'd be much happier with larger tires, say LST or MGT tires. "
DirkDigler said:No one told you? After you are done, you have to soak the tires in sulfuric acid for one hour. That cleans up the areas that you cut up. Works like a charm. After they are done soaking, you will see a big black pile of rubber at the bottom of the acid. Don't worry, it's normal!:wink:
SR5Dave said:I've got a TON of play on my tires; I can turn the tires about 10 degrees or so before it starts to turn the inner axle or gears :?
I still haven't managed to break an axle though!!!!!! Or gears; which im surprised at.
