dodgeboy8888
i need to waterproof my tekin fxr ive seen djmedic dip it in plasti dip but here in canada i only found the sray plsti dip. would you trust spraying it ?
anyone know of any other fully waterproofed EScs???
Bingo! "thumbsup"when you encapsulate your electrics with it it holds in heat..
waterproof Esc's..
Castle sidewinder 3
Hpi flux vapor
Hobbywing WP series
Trackstar waterproof
Venom Waterproof
Traxxas xl-5/vxl
AE LRP Waterproof
waterproofing electrics you need this corrosionX..
CorrosionX for use on electronics
just dipped my MMP esc and my tekin 13.5t brushless motor..
so far so good..@$25 shipped to my door.
Grainger CORROSIONX Corrosion Inhibitor Penetrant Lubricant - Penetrants and Lubricants - 4AAA2|91002 - Grainger Industrial Supply
or
Superiorcarcare is where I bought mine.
CorrosionX Penetrant & Lubricant, corrosion x lubricant, rust inhibitor, rust remover
You dipped your MMP and motor in corrosion x? It looks like a spray bottle? did you spray it on? I just bought an MMP and am interested in waterproofing it that is why i'm asking for clarity. thanks
dip it or spray..
dipping is a more efficient use of the liquid..
spraying it just runs off and you waste a lot more.
find a small Tupperware bowl pour some in it..
decase the esc and dip it in and let sit for a few minutes.
pull it out and let drip dry for 4-6 hours.
I let mine dry for a whole day just to be on the safe side.
If you rush it you can burn up the esc by powering it up too soon,if there's still an excessive amount of liquid still on the board.
visually inspect it for standing fluid..give it a good shake to make shure
all excess liquid is gone before reinstalling it into case.
Just finished up with some waterproofing using both CorrosionX and conformal coating. I've not dunked anything just yet, gonna let it dry overnight. I used the CorrosionX on my Savox servo, Castle BEC, and ROC412 motor. The conformal coating was used on my MMP and RX. Really hoping it works as described, I've been wanting to do some water crossings and stuff.
The conformal coating I used was a urethane brush-on version, I also have an aerosol acrylic version that I did spray an extra RX with to try out.
How did you waterproof your roc412? Just spray it on the wires?
I took it completely apart, soaked the can, sensor board, and rotor. Then I let it all dry seperately.
The CorrosionX, it leaves a film behind, I lightly dabbed off the excess. From what I've read, some use compressed air to blow off the excess. It is not thin and clear, I have the aviation type, it's green and similar to a light syrup in consistency. I powered everything on this morning and all seems well.
Let me know how all works![]()
Question, on my ROC412 where the wire leads venture down into the motor, there's a bit of a gap. I had some liquid electrical tape on there, but when I pulled everything apart to dip into some CorrosionX I noticed there was very thin amounts of the liquid electrical tape that had crept down and into the motor endbell. I'm not particularly fond of seeing that. What should I use to fill the gap? I thought dielectric grease, I don't want the heat of the motor to thin it out (if that's possible). Or just put another coat of liquid tape over it? Leave it alone?
Left side of pic is the area I'm speaking of.
Thanks
