viper6171
okay i know i didn't post alot of pics in my build but i was running tight on time , i finished it at about 1:30 am on to the pics ( the panels that are on it are temporary )
bahahahaha thank god there only temperary, rig looks good thou. hope u do good at ur comp "thumbsup"
i got some new tires for my venom to and was wonderring to if i need to drill vent holes in my stock wheels?if so how many and where?im a newbe so please help me out im 55 got 7 nitros and now one venom custom frame im building now.id like it to be tops maybe later compeat a little i love this crawling!!!lots different than my speed deamons!!!!well like i posted earlier the 10x15x4 hub bearings were bad but i found another problem i guess the pin holes in the axles ( for the hexes) are just a little off ( to close to the hub ) so when you tightened the wheels up the hexes were pressing against the hubs and putting alot of pressure on the inner bearing so i found some different hexes for now that the slot in the back isn't as deep as the creeper hexes ( fixed that problem). we are having another comp this sat so i will see how it works now ( also drilled vent holes in the wheels so the tires weren't air filled balloons ) still need to move some electronics down lower to help with cg may also find a new home for the battery .
thanks a million!!!i dont even no how to do pics yet but im gonna try...my rig is axialjeepteers green venom i just bought it now need to complete i think a pic is on pg 64 of his build?thanks agian ive been reading all info i can your build is next!mine has venom bottom end the frame roll bar assembly is made by axialjeepster he did real nice on it ...he builds custom parts and frames...The best thing to do at this point is to start a build thread of your own..post pics of what you have and ask questions etc all in one place....
on that note...one 1/8" hole in each wheel should work fine. drill them in the center of the wheels
Those tabs on the BTL plates are meant for people that dont have trusses on their axles...you can mount your uppers to it though...thats what they are there for...but you may run into some clearance issues...Im so used to the axle roll now that it doesnt bother me considering the gain I get from what causes it.
on another note i finally finished the paint on my short course truck , gotta say i really like spaz stiks paints . i went with candy apple red and silver metallic backer , also used fastcolor black . here are some pics ( which don't due it any justice you can't see the depth of color or all the metal flake in it )
