viper's creeper build
okay so i finally got a chance to take the creeper out on some rocks (just a bunch of rip rap ) i want to go out to one of the places that we comp at to test further . the creeper deffinately did better than before , but i have a question for any and all who read this i am running an 18 tooth pinion gear on my creeper with a 55 turn integy motor and sidewinder speedcontrol with 11.1v lipo , is this to big of a pinion cause my motor got pretty dang hot in a short time now before i was using a 12 tooth pinion and didn't have this issue any ideas ?
you might try bringing the pinion down to a 16 or 17. Youl still have the wheel speed from the 3s but will cut back the heat development a bit.
well my new wheels arrived today ( sorry i have to use a stock picture ) got them mounted up with my rovers but i have to modify my creeper hexes or get some different ones ( the little nub that sticks out in the center is in the way ) , also have to say that they were a load of fun to mount the centers are approx 1" wide . okay here is a pic
okay question has anybody had a problem with aftermarket wheels not fitting on creeper hexes due to the little protrusion in the center of the hex ? do i cut it off or do i attempt drilling the center hole on the wheels bigger ?
well when i was putting the wheels on the creeper one of my factory stub shafts snapped off right at the end of the threads , found out from the guy that i got it from that it was one of the first runs that had the overhardened shafts . so now i have to replace that one unless venom will send me some replacement ones .
well i still had one of the stubs from the front ( replaced with flm stubs ) so i put it on tonight so i could comp this weekend , well i ran into a small problem went to tighten the wheel and " pop " another stub axle broken . and i made sure that i used less pressure on the nut than the last time so i guess it is just the problem of overhardening ( my creeper was one of the early runs that had bad axles ) found out from the guy i bought it from that he had it since the first ones came out . "thumbsup" i sent an e-mail off to venom and am waiting to hear back .
