viper's creeper build
no thats probably not a good thing venomcrawlerdud could possibly come apart on ya .
well i finished putting the creeper back together got all the new bearings installed ( thanks avid ) got the new xvd's installed ( thanks rc4wd for making more of these ) also got the new chassis installed as seen in the above pics ( thanks dinky r/c for a quality product ) . i will get pics up soon of the new creeper . i need to get out and test it once the snow melts off and i can get to some rocks without sloshing through 6" of mud :shock: if it works the way it is i have massive ground clearance so we will see "thumbsup"
okay first test run is over ............... to tall ..................
anybody got a set of 90mm shocks they want to get rid of ?
well not that i want to get rid of mine. im running the pro-line powerstroke scaler shock. they are 90mm or 95 if you change the rod ends. they work great. im very happy with them. they are just a real pita to bleed...i was quoted $30 from my lhs. which is cheaper than alot of online retailers. they are also a smaller diamater shock body, which worked great with my limited space of the chassis and steering that im running.
http://prolineracing.com/performance-parts/power-stroke-scaler-shocks-90mm-95mm/
much better with the new shocks and the new chassis is working well , i went to one of our local comp spots and ran some of the lines that i had problems with or couldn't pull off at all and i pulled off almost all of them one is almost impossible to get because of an undercut that is almost exactly as tall as a rover tire . our first comp of the year is this saturday so now i just have to remember how to drive :shock: and i will post some pics of the new setup maybe tomorrow and pics of the comp on sat
alright creepers this year is starting off well , we ran our first comp sat and i finished 2nd in sportsman :shock: i am quite happy with the new changes to my creeper . now for some pics and if i can a link to one of our new guys videos of the comp
and yes i did have my front driveshaft ome apart
and here is the link to the video http://vimeo.com/21249489
i got a question for you viper, how is your steering setup? is it stock or have you done something to it?
well it is basically like the stock setup i made a new connecting link because the venom rod ends were binding up bad ( ball didn't want to rotate ) so i made a new one had to trim the ends to allow full turning then i bent it in the center to clear the center of the axle case i reused one of the old upper links as a draglink and now my steering is nice and smooth "thumbsup"
is that chassis still available, is the creeper skid an option? i love the way it looks and how well the VW body fits it!"thumbsup" ive have 1 of those bodies sitting here in the bag, but dont think it will suck down that low in the stock chassis....
yes the chassis is availible , i'm not sure how much it would be because you don't need the skidplate or the chassis braces that it comes with . the designer of the chassis is looking at making a direct fit version for the creeper ( i made adaptor plates for mine as it is the first creeper to be used in this chassis ) i will get a link for the chassis maker he is a good guy tell him i sent you and that it is for a creeper
hope this link works
http://www.rccrawler.com/forum/showthread.php?t=271788&highlight=dinky+r/c
