Venom Creeper Picture Thread
This is my first crawler
Novak Goat 3S esc and 18.5T brushless
Integy cage with modified shock mounts
esc on rear link tray, battery on rear axle
Rear axle steering links moved up and skid removed.
more body panels in the works
Venom Creeper kit
2.2 Sportsman Rig
RMDW VULTURE XR-X Slant CHASSIS
RMDW Paradox Dual Disk Foams
RMDW Paradox Pin Lox cvd pin retainers
RMDW Paradox Rear Axle Truss
RMDW Paradox Front Axle Truss
RMDW Paradox Truss mounted BTL servo plate
RMDW Paradox BTA steering linkage
RMDW Paradox Lincoln Lockers front and rear
RMDW Paradox Battery plate
RMDW Paradox XR-chassis stiffener kit
CBRB Titanium rear axle shafts
Rovers White Dot siped
Integy 55t lathe motor
19 tooth pinion
40.8:1 final drive gear ratio
Novak The Dig, dig switch
JR DS-8711 servo, mounted inverted
Robitronic long aluminum servo horn
CC BEC 10amp
Tekin FX/R esc, mounted to front of motor
3S lipo
Lipo on front axle
Traxxas Steel yokes and Long Truck Shafts cut to fit, 3 piece spring shaft in front
Losi 4" shocks w/ White springs and 25wt oil
Spektrum DX3E 2.4 ghz radio w/ SR300 Rx (decased)
Hot Racing Aluminum C's
Axial AX10 Zero Ackerman knuckles
Hot Racing Aluminum rear lock outs
2.2 1.5" wide CKRC Link "Murdered Out" Wheels w/ Berg Gold rings
Shaved axle housings
Modified front suspension for 50*+ steering angle
RC4WD XVD axle shafts in the front
Hot Racing Aluminum Trans Skid plates
3.5mm bullet connectors for motor disconnects and the battery/esc
Droop rear suspension, Sprung front suspension, stretched stock Creeper internal springs used front and rear
The rear lower links are stock lower links with the long bend straightened and 1.25" cut off to retain the 12.5" wheel base. Front and rear lower links are relocated to the side plates and the transmission is resupported by adding 4 rod end balls back in under the trans to take the place of the stock links. The rear upper links are stock. Front Upper links are custom delrin.
Current Photo RTR weight 5.2 pounds....currently, no additional weight in the wheels.
Heres the Paradox'd Creeper with the Paradox Vulture Talon MOA on Bully axles
mine with some slight adjustments.
Although not excited by the quality, I blew out both driveshafts on its maiden run:roll:
