BrotherAndySLB
I did disconnect one driveshaft from the trans and pushed it forward and back, clicking can be heard within the transmission.
Just a bit wary of disassembling the innards, any clue on how I can get to that input shaft bearing? Should it just be lubed up or a replacement is necessary?
Its not that hard of a job. Download this manual Ascender Kit Manual Then go to page 18 and start going backwards to page 1. When you are done servicing the transmission start at page 1 and go forward to page 18.
Basically what you want to do is remove the two drive shafts (4 grub screws) remove the 4 screws holding the trans on, disconnect the motor, take the single screw out that holds the motor cover on, you may have to remove the pinion from the motor, take the two screws that hold the motor on out to remove the motor. Then remove the single nut holding the slipper clutch on (hold the spur gear to remove the nut) Then remove the 4 long screws that hold the transmission together two of them are 1.5 mm two of them are 2.0 mm. My rear input shaft bearing (the one that is on the back of the shaft that the slipper clutch goes onto) was bad as well as others that I have read about. It was hard to diagnose for me because when the transmission was open everything moved great. I would go ahead and take it out first and see if you can find anything wrong with it.
If you already hear a loud clicking sound I'd say replace that bearing. The manual will tell you the exact sizes of all of the bearings.
