Vanquish Products R-2
Vp Monkey
Vendor
sacramento
We are releasing a new version wheel the Revolver R-2.
***** $49.99 IS FOR TWO WHEELS ******
This set includes the following, 2 wheels, 4 bead locks, 24ea. sst 6-32 x 5/16 button head cap screws, 6 weight screws.
Wheel is made of billet Aluminum 6061 and is 2.2 Diameter x 1.1 wide with 12mm hex. Each wheel weighs 4.8 oz.
(Pictures below in same order)
Track width for a Axial axle = 9.062
Track width for a Berg/OCM axle = 10.00
Track width for Wheelie King = 10.062
each wheel has one 1/16 air vent hole pre drilled
Has options for colored beadlocks, and soon for colored wheels as well.
Weights are not included.
each wheel can hold either 2, 3, 4 or 6 vanquish wheel weights.
Patented and other Patents Pending
Made in the USA
Cheers
Thomas
So do these weigh the same empty as the DH Pros do? Because I want another set of vanquish rims, and these are perfect as long as they weigh the same, as these would be testing wheels then when I find a weight/foam/tire setup that works I would put them on my DH's incase I want to change offset. Thanks in advance, Keith8)
You could have atleast put thaty shock back together before you took the picture.
They look good though."thumbsup" Any chance of offering them in Axial offset too?
no a DH weighs about 6.2 oz.
<HR style="COLOR: #191b21; BACKGROUND-COLOR: #191b21" SIZE=1><!-- / icon and title --><!-- message -->why go to a narrower r-2 wheel than the dh comp and have the same track width on the berg ??.:idea: it would of been great if they had a 9 1/2" track berg width "thumbsup"
<!-- / message --><!-- sig -->__________________
TEAM CDW DRIVER
CRAWLER DESIGN WORKS
NOR-CAL RCRC
TEAM CDW DRIVER
NOR-CAL RCRC
the demand wanted a cheaper cost dh procomp, we are building narrow berg wheels right now,
