Vanquish Currie F9 AR45P axle housings
Topher Builds
Las Vegas
Just dropped....
https://www.vanquishproducts.com/axial-scx10-iii-currie-f9-front-axle-black-anodized/
Currie F9 Portal Offset Front Axle for Axial SCX10-III
The Vanquish Products F9 Portal axles are a machined aluminum housing featuring integrated C-hubs for strength and style while also incorporating increased caster for better steering performance in challenging terrain. This design allows for more steering angle compared to stock. Link mount spacing has been modified to fit standard Incision pivot balls, all pivot balls are included with the housing for replacement in the factory rod ends. This housing is compatible with stock SCX10-III gears, knuckles, locker/spool, suspension links and shocks.
Features
Offset Pumpkin
Machined Aluminum Construction
Increased Caster
Over 50 degrees of steering
Removable upper link mount
One-Piece Machined Bearing Retainers
Includes:
Axle Housing
3rd member
Removable front upper link mount
Suspension link pivot balls
One-piece bearing retainers
Required hardware
Note: Axle is designed to work with factory Axial branded SCX10-III components. Vanquish Products cannot guarantee the fitment of other aftermarket brand components with our axle housings.
