Bart bender
Do you know who makes it or is it a CEN product?
The CEN lock is a GS013
Didn't See a List of whats needed to build a set of axles but here it is, May need to be double checked in case of errors. for the Differential Part lists I went off a Inferno, I Couldn't find a Mad force diff breakdown list.)
The IFW 421-01 is just the shaft. Also the IFW422-01. Do you no the dimensions of these complete?
IFW421-01
IFW421
IFW422-01
IFW422
IFW421 is 84mm.
IFW422 is 110mm.
http://www.stormerhobbies.com/cgi-b...=IFW42&mterm=&oterm=&uterm=&sthumb=on&smode=0
MACHINED BULLETPROOF DIFF BEVEL GEAR 29T/9T SET :shock::shock::shock:
Has anyone tried any of the gears for the "SAVAGE FLUX"
to know if their a "drop in" replacement?
If not I will confirm on Saturday when I go to "Larry's RC's
Regards V8
Regards V8
Nope..........
Wont work......:evil:
Savage gears are to big.......
Darn
V8
Thanks for any info guys, I'm just seeing the light and thy name is mad/twin force axle
Well, I guess the only thing to do is try them out. If you got'em laying around than order some housings and give them a whirl"thumbsup"How about the pre-bp diffs from the savage nitro?(43/13)
Edit: Just looked on the front page and a kyosho straight tooth version of 43/13 is listed as fitting, but how bout the hpi? I've got a few savage parts layin around.
Welcome to the club.....;-)
Regards V8
And yes welcome to the sickness. Start a tech thread too. Let us know how they work"thumbsup"
Creep, you may have just made my day with these shafts. Do you have any pics of the shafts apart and maybe some measurements, total assembled calapsed and fully extended. These will cure the Moly pinion delema some people are having. Can't drill them for Revo shafts they're too hard.
GS043
GS040
Also looks like there are a lot of usable parts from that truck GS/GSS
I can confirm the GS013 Lock Block works. Thanks Creep"thumbsup"
