Bart bender
Should just drop in.
Here's a couple Kyosho CVDs (actually U joints) that will work.
Thanks Reflection and CDW for the info.
Here is a CV Tech thread I started, and lost track of, with some very good info: CV shaft tech - RCCrawler
IFW162
These are same length as the long side according to CDW
IFW142 (90.7mm long) This will get you 1/4-3/8" wider than 2 short sides.
Stock short side. Actual length, pin centers, 91.1mm
IFW162B These are long.
With stock long side. Actual length, pin centers, 129.69mm. Gonna have to mod these to work.
IFW163 These are also long but you can run 14mm hex.
hello bart,
I just purchased a new cruiser mad force (long wheelbase).
I can mount the codes (IFW-162B) lunogo side and (IFW-142) the short side, without modifying anything?
greetings.![]()
Love all the info. But what would be the strongest diff and gear set for the mad force. I know people are putting 4000 watt 6s setups in savages flux's. Will the flux diff fit?
They do look smaller. Length would be an issue too. As long as they are the same length I don't see why they won't work.anyone know anything about these? they look like could be pretty usful. but for some reason i thought i read somewhere that they are 6mm shafts, which mean we would need to find 16x6 bearings.
New OFNA Universal Joint 2 15100 | eBay
https://encrypted-tbn3.gstatic.com/...iKWugK6ADGATc4wYMPq86Sx2f_IHicZ-MLQO&usqp=CAY
My MBX6 diffs use the same bearings, 16x8, the only difference I see is the 4 bolt battern for the gears (spur/ring)Will Mugen mbx 5 6 or 7 diffs work?
