I'm really digging this chassis. Just one question, you do custom orders? I really love the idea of the 1/2 inch rise in arches but I would love to utilize that feature and be able to compress the axle all the way to the frame. I am currently having a buddy 3D print some longer shock towers for my factory frame so I can get the whole rig sitting lower. I swapped to bigbore shocks and the bodies are much longer than the stockers, here's a pic of what I'm talking about. Look at the amount of space is there before the axle touches the frame.![]()
So I would like to have either rows to mount the shock in different spots vertically or taller shock towers
Just bolt a riser to his shock mounts to raise the mounting point higher..... Would be no need on stock hoops to remake..... Just use a riser plate.
Can that chassis work with the titanium Vp links ?
yes you sure can"thumbsup"
Price Drop!
I was able to purchase a larger batch of these and got a quatity discount. So im passing that onto the customer! $10 price drop!:shock:
In stock and ready to ship!
Chassis -
Seems the upper link is too long and giving me a bad clocking of the front axle...
you can put the upper link in the stock hole, or run shorter uppers/rod ends if you want to take advantage of the SCXHR upper link riser geometry."thumbsup"
Is that the blue monkey cms plate? Does the servo stick up above the shock mounts on this chassis? I ask because I need to order a cms kit for this chassis. The blue monkey kit is at the top of my list but I'm worried about fitment on my rig. Do you have more pictures of this build?
