TRX4 wheel fitment info
Guys I would really like to get some old school Landry steel wheels. I was thinking about these. https://www.ebay.com/itm/192211845220
What hex would I need to make these work?
Would the stock hex work?
What is the stock hex size, so I could upgrade to steel?
I think the RC4wd Landies are the best looking one if you like original Land Rover Style. It should fit directly but you need to drill the center hole from 4mm to 5mm like I did. The stock hex should be 12mm. I think the still hex is already steel and I dont think it will be easily stripped.
Anyone try the RC4WD Rock Creepers 1.9? Love the look, but not sure how they will look as they are pretty short 96.5mm.
They would look incredibly tiny with the D110 body. These are 4 inch tires and they look small on a stock TRX4, Rock Creepers would be even smaller than that.
There is also the fact that the X3 soft & sticky compound, despite it's name, is neither soft or sticky. Consider the Proline BFG Krawlers or Hyraxs for a similar tread pattern in a much better performing tire that fits well on the TRX4.
Anyone know how these would look and work?
RC4WD Mickey Thompson Classic Lock 1.9" Internal Beadlock Wheel
Also if they would look ok and work ok, what would be a good all purpose tire? Not looking to do any serious crawling, more of an all terrain. A Little Rock, dirt, mud, hills, I live in a very diverse area lol.
I have rc4wd 6 lug white spokes with baja mtz’s on 1 of mine and it looks good for fit if you look in my pics i have 1 with simular looking wheels to give you an idea
That would be great. Just don't want to drop that kind of money on them and they look silly or I have to do a crap ton of trimming.
Does anyone know if the SSD portal covers will work with PROLINE flatline or denali wheels?
I have the wheels, and want the SSD covers, If not I will buy SSD wheels as well but hoping to spend that cash on something else if possible.."thumbsup"
Thanks
Anyone already tried BoomRacing Krait wheels?
Got some Venomous Krait wheels from a project I cancelled, and might throw them on my TRX4 when it gets here
Thanks!
I'll wait with selling them then :)
And ofcourse will post some pics here when the TRX4 is here and I mounted them :)
Just tried the BoomRacing Venomous Krait wheels.
They hit the portal cover with the screws that hold them together, possible solved by using a hex screw with a smaller/flatter head instead of the large ones supplied.
And I cannot tighten the wheel nuts enough, they hit the end of the thread before the wheel is fully tightened
Also the supplied wheel wideners do not fit the TRX output shafts, they need to be drilled out by about 1mm to fit.
Thanks
Doesnt need to be ssd wheels to fit I'm using motoworx and fanquish wheels on mine and they fit great. If you measure the inside of the wheel I can measure my ssd covers later.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Ok. So if I'm taking all this information in properly, all I need to do to make the RC4WD 5 lug White wagon wheels I have fit my trx is drill out the center that fits over the axle and swap the rear pin drive adapter to the hex one.....anything else? I picked up a set of these wheels already from my LHS before i even took into account the differences with these axles and if they would work. I really like the classic white wagon wheel look so I want to make them work. They will be paired with TSL/SX-XL's........
Yes that is correct all you need to do is open up center hole and get hex adapters I’m running the black rc4wd wagon wheels on mine
Not sure on how it will hold up, but a small washer of 1mm between the hex and the Krait wheels is enough to clear the portals and to be able to fully tighten them
Just finished mounting following config fits perfect (incl. Codyboys Front weights):
SSD Rockracer 1.9", 475 SLW, SSD Wheel Hex
used rc4wd pro-line inner rings to make the hyrax fit
