Our Iconic SLW wheel was designed to mimic the classic 8 hole wheels made by Mickey Thompson.
This wheel uses 1 external and 1 internal ring and WILL work on trucks like the Axial Capra & SCX10-III.
What's included:
-1x 1.9" Iconic SLW Positive Offset Bright Finish
-1x Internal lock ring
**Please note that these wheels are Positive Offset and will sit 5mm inboard compared to our standard wheels.
These are intended to be used with portal axles and may interfere with standard axle knuckle setups.
If you want to space them out to be near standard/stock track, use a 350 or 415 SLW wheels hub.
350 will be slightly narrower than stock, 415 slightly wider.
Thanks for reading!
