Barndog Racing
What about the Rc4wd Landies anyone tried these?
350 Hubs make it damn near close to stock width. Go smaller if you want full coverage by fenders and larger then 350 if you want a wider track width. As I understand it, this is with all the VP KMC and Method wheels.
And it wont rub on the portal? if this is the case I will buy them right now lol
I make my own foams, so from experience, a little wider foam at the tread will flatten the tire out nicely. "thumbsup"I know I will inevitably strip out the stock plastic wheels, as that is the fate of all 12mm hex'd wheels when used with locked diffs . In my hands at least...
I'm actually liking the stock tires though, and would like to swap them over to more robust wheels. I'm thinking some white steel wheels, brand undecided, would go well with the old Bronco body I'm running.
My concern is that either the steel wheels are too narrow for the stock tires and will result result in a rounded tread profile, which I consider was than ideal. Or maybe that the steel wheels will be spaced out farther than the stock wheels, adding undue scrub radius and stress on the front axle. I've never had a set of steelies in my hands, so I'm not sure of their exact specs.
Could some one please post front view pics showing the track width and tread profile with some steel wheels? If the Steelies are too skinny for the stock tires, or add track width, could someone recommend a set of non-fancy looking wheels of appropriate width and backspacing to run stock tires?
I think if I ditch the stock hex's I must find 6mm id sleeves/ shim to simulate the inner protrusion on the peculiar traxxas hex. Otherwise the axleshaft floats slightly on the slot in the lower portal gear. Probably not enough to hurt anything other than my ocd, but nevertheless I can't have it.
I guess I thought the rc4wd steelies always came with pin drive 6-bolt adapters that won't work with my setup?
Installed my eBay 1.9 Alloy beadlocks, plenty of clearance with the MFR Portal covers installed.
Hey DJ,
Would it be possible for you to take some side view with the body on pics to see how far the tiires stick out past the flares? I'm looking for views like NateDog showed us in post #87.
Thanks!
