TorqueMaster Pro Handwound Rock Crawler motors
Re: TorqueMaster Pro Handwound Brushed 540 motors
I ordered a Torquemaster pro 30 wind and BRXL combo a little over a week ago. My order says Backorder on the invoice. Ive sent in emails with questions regarding a possible ETA on the items with no replies.
any info you might have would be awesome. Ill try contacting by phone tomorrow to maybe get an eta. thanks!
I ordered a Torquemaster Pro 27t on the 23rd and it showed up today?
hmmm...yea i don't know mine has been labeled backorderd since the 23rd. Id kill to get mine shipped being that im at a crossroads and cant finish my new mog build ive been working on for months.:cry:
Just got a 27t torque master pro
I do not know the first thing about the motor anatomy or maintenance. Is there any good tutorials someone could suggest?
Do I need to buy a ton of replacement brushes up front?
Ive owned probably 4 of those. If you over gear it have a good supply of brushes. It is a killer motor though. Plan on running in water or mud? If not, just keep the bearings oiled up and check the brushes and you will be fine."thumbsup"
I have my 27T geared with 32P 56 / 12
motor getting warm anyone suggest a better ratio ?
I do own a 11T pinion not sure what I should use for sure....:shock:
New Order of Holmes Hobbies Torquemaster motors and Waterproof ESC's arriving this week.
Our customers have given great reviews on anything Holmes
RRW Krawl Zone
Belleview Fl
rrwstore@gmail.com
Just ordered a 45t from RPP. What brushes are suggested for replacement?
I heard that 35t is out of stock on the HH end. RPP is not my source for this info. Is this true?
I'm sure this has been answered before many times but can I run my HH TM pro 27T on 3s.
Edward
I'm going to send in my motor for repair today I think the brushes need to be replaced. My question is I have a Scx10 with big old rc4wd 2.2 Mudslingers XL's and they are mounted on aluminum RC Locked up wheels. A very heavy setup all RR gears running right now. Running 15/87 gears and a TM Pro 27t motor. Would you recommend a diferent motor everyone keeps telling me I need 35t or higher turn motor on it because of the weight but I have no issues with it at all.
Edward
Not 4s though. Haha I found that out. I gueas unless you gear way,way down, no brushed motor will handle 4s for any sort of crawling/bashing. My HH pro 35 lasted about 2hrs then quite. Pulled that and burnt up a integy 65turn ,with 20 pinion ,and 80 spur in minutes. This was on a wraith with 2.2 pits. I guess I need brushless
I run everything on 3s!
I have one of your 27t's I need to stop by and have it rebuilt. But as far as gearing goes. The truck is on 2s a.t.m but will be seeing 3s soon. What gearing do you advise? It has the axial 32p 56t spur with a 16t (or whatever stock is not 100% on that) I do have an 11t and 12t laying around. What should I do?
i think mine needs new brushes, it wont move,but if you turn bye hand it will try to.
do you think thats it?
could be a stuck brush? pull on the shunts and let the brushes snap back. If that doesn't work pull the brushes out and look at the com., if the brushes are real short or the com. looks burnt it will need a rebuild.
I picked up a 35T torque master expert and i gotta say i really like it. i can see it's better than my Tekin 35. happy to get a great motor. thanks jon.
ordered a motor and received the wrong one but was curious if it will work in my axial wraith.. It's a Holmes hobby torquemaster pro 550 27 turn motor I ordered the much cheaper 540 can 27 turn motor that was 18 bucks lol thanks for your help
Pretty sure that I remembered hearing that you contacted us. As evidenced by my slow response, forum isn't the best way to reach me.
John.... Understanding that this isn't the fastest way to reach you...
I'm not in a hurry! ;-) In Fact, I'm opening up a 30t TorqueMaster Pro purchased over 2 years ago. It didn't have Stickers with it.
Do these not come with stickers??
I know this is a silly question, I was just wondering. Why it wasn't opened for 2 years... I just don't have a good answer!:lmao:
We had probably run out of them at the time. We typically put two stickers into every product box unless out. Now that our inventory system tracks stickers as sub-assemblies of products, we are less likely to run out.
