Jfannin
Yes, normally green for go and red for reverse..Quick question i hope
First crawler.....
With the be mini are the should it light up green going forward and red when backing up?
Don't know if it maters but I didn't ever connect it to castle link or anything. Just wired it up and tested. Also I'm using a FM dual stick heli tx...
Thanks
What tx do you have? Did you calibrate one esc at a time or both at once?So this one goes out to John, I just got one of the smashed units. I had a BEC smashed with it, how do I set the voltage on the BEC? With out cutting open the wrap and un soldering one of the leads to it. I'm assuming it's set at 5.1v. Also after hooking everything up my rear lags. It didn't do it with my FX-R's. I've checked the mesh on the rear and front. Nothing is binding, any thoughts?
Can you post a pic of the smashed in bec? I just want to see how it's done.
You should be able to just plug the bec into the castle link to set the voltage. Not have to unsmash/open anything up.
If you can't program the BEC normally, plug a battery into the speed controllers and it will boot everything up and let the computer see the BEC. The 5v USB source isn't quite powerful enough to boot up multiple products, most of the time. Good suggestion about the BEC voltage on a combo, we will add that if it isn't already.
Your startup issue will be caused by one of your throttle channels having a different neutral trim. Adjust one channel or another until they startup the same.
Any advantage to upgrade the 1.08 firmware to 1.09 on the first gen BR minis?
With CC link
Envoyé de mon Nexus 5 en utilisant Tapatalk
The current mini will absolutely take it.
They will run hot without some mods.
