sgtsteve
Also, the RC4WD winch creeps AWFULLY bad. It has a potentiometer to adjust the trim, but as soon as you operate the winch at all, the creep is back and it needs adjusting again. This happens every time! It can't be operated like this so I'll have to look into a way to address it. I suspect I may need to pony up for a heyok winch controller. Kind of annoying, though.
I dealt with the same thing Tommy and tested it at different voltages (5, 6 and 7v via BEC) without change. The issue turned out to be the battery voltage, as I was using a 3s, which doesnt make alot of sense since the power to the winch was limited by the BEC. I dont know much about how electricity works, so maybe its amperage that was the issue, but on a 2s it should work fine. From what I read the heyok controller works fine with the bulldog winch, regardless of voltage used.
