This is my first build thread, and first scale / crawler build.
I started with an Axial Wraith RTR in August of 2011.
My current build consists of:
Electronics
Battery: a 3s 2300 mah battery from the LHS (don't recall brand) or a 2s 5000 mah battery from Racer's Edge
ESC: Holmes Hobbies BR-XL ESC w a 10amp Castle Creations BEC
Motor: Holmes Hobbies Torquemaster 55T motor
Front-Servo: HiTec 7955
GH Racing Servo Horn II
Rear-Servo: Futuba BLS452
Racer's Edge Aluminum Servo Horn
Radio: Spektrum DX6i How I configured the DX6i
Front Axle:
Internals: Stock
Externals: Vanquish Steering knuckles, C Hubs, Lockouts, and RC4WD ARB Transmission Cover
Steering Linkage: Level 3 Racing Steering Link
Traxxas aluminum toe link for the drag link
ST Racing Concepts Aluminum Front Servo Mount Block w Upper Link
ST Racing Concepts bottom shock mounts.
Rear Axle:
Internals: Stock
Externals: Stock knuckles, C Hubs, Lockouts, and RC4WD ARB Transmission Cover
Steering Linkage: Stock
ST Racing Concepts Aluminum Rear Mount Block w Upper Link
* ST Racing Concepts bottom shock mounts.
Transmission:
Internals: Stock top and main gear, Robinson Racing Idler gear
Spur and Pinion: 11t pinion / 80t spur
Driveshafts: stock with aluminum rod inserts
I removed the aluminum rod, decided I'd rather twist a drive shaft than smoke my motors.
Suspension:
Links: Vanquish Titanium Upper & Lower in the Front & Rear
Shocks: G-Transitions from RC4WD
Level 3 RC droop kit on rear
Wheels & Tires:
Wheels: Axial 22 8-Hole Beadlock Black (AX8097)
Tires: Losi Comp Claws 2.2 Tires w/Foam (Blue)
Body:
Hood by Dinky RC
Traxxas battery mount pins for the hood to hold it in place, wire ties as hinges in the front
Side, rear, and roof panels - self made sheet metal
Battery holder under the hood - self made sheet metal
Windshield from RC Bros
Custom Wraith Bumper from MG200 here on RCC including d-rings
Custom Wraith rear stinger bumper
Accesories & Misc
3Racing crawler winch
RC Screwz stainless steel screw kit
Tow chain
Custom plate for passenger side to mount Go Pro HD (used occasionally)
Go Pro HD for first person view filming (used occasionally)
RC4WD King Kong Tow Shackles
Rear mounted spare tire (used occasionally)
Snow Chains (used occasionally)
Modification Notes:
Receiver box and ESC have been moved back up front, crammed under the hood along with battery
2S 1000 mah for winch and room for up-to Venom 3s 2300mah for primary power
Updated: 03/13/2012
Current Photo (Not Current no ones soon...)
This is my custom passenger cover and first person view camera mount and spare tire attached.
Hitec 7955tg servo, Racer's Edge Server Arm, and a Traxxas toe link as my drive link, you can see the RC4WD Transmission Cover, new C Hubs, and MG200's beautiful bumper.
A look under the hood. A 3s lipo for running, and a 2s 1000 mah for my winch.
Full Photo Album: https://picasaweb.google.com/randquistcp/RCAxialWraith?authuser=0&feat=directlink
You can see all of my Axial Wraith related RC videos here.
Electronics
Front Axle:
Internals: Stock
Rear Axle:
Internals: Stock
Transmission:
Suspension:
Wheels & Tires:
Body:
Hood by Dinky RC
Accesories & Misc
Tow chain
Modification Notes:
Updated: 03/13/2012
