dezfan
I like it!
FEATURES
CMS (Chassis Mounted Servo)
Adjustable front track bar
Universal front drive axles
Stamped steel frame rails
Enclosed receiver box
12mm wheel hexes
Adjustable front and rear bumper mounts
Adjustable width rock sliders
Two battery boxes
Aluminum motor plate
Adjustable body posts
Optimized ball cups for more fluid axle articulation
Adjustable rear shock mount positions
Telescopic driveshafts front and rear
Extruded aluminum driveshaft splines
One-piece rear axle design
Splined front axle with adjustable caster
Machined input pinion gear
Metal ring gear
Machined steel top shaft
Metal idler gears
Heavy duty 5mm diameter steel links
Metal ball bearings
FEATURES
12mm wheel hexes
Two battery boxes
Metal ring gear
Metal idler gears
Metal ball bearings
