Techno Duck
I caught the solid axle MT bug earlier this year. I was looking for something to run in the yard on grass. Kraton was too fast and the Baja Rey isn't great on grass. The SMT10 is a lot of fun to drive and watch, with the solid axles and big wheels even minor things are done in a very dramatic fashion.
Axial discontinued the SMT10, but i was lucky to find a new one from HobbyKing. They are pretty boring out of the box and need a bunch of upgrades for durability. As soon as it arrived, i swapped out almost everything that could be problematic.
After 15 or so packs running around the yard jumping skateboard ramps its been holding up great. Out of all the rigs i have, this is my favorite. Even in a small area its still a lot of fun. I primarily run 2S but have put a few 3S packs through it. Its fun on 2S and still has enough power to do standing backflips with the punch all the way up. On 3S its wild and i imagine even with the upgraded parts will still break things.
Ive got it pretty dialed in now, ill post more details about it over the next week or two.
Parts List
Max-D SMT10
Drivetrain
Vanquish transmission case
Vanquish Incision gear set
MIP Driveshafts
XtraSpeed Axles
Axial front CVD’s
Vanquish rear axle shafts
Front diff packed with grease / rear diff has 100k oil
Axial HD ring and pinion (not yet installed)
Suspension
SSD trailing arms
Vanquish Incision upper links
Vanquish Incision steering links
Kimbrough #124 servo saver
Proline Powerstroke XT shocks
Axial front sway bar
SSD front knuckles
Vanquish scale front clamping c-hubs
Vanquish clamping rear lockouts
HotRacing 100mm limit straps
RH Design wheelie bar
Wheels / Tires
JConcepts Tribute wheels
JConcepts Golden Year tires
Electronics
Castle Mamba X
Castle 1410 Green Can 3800kv w14t pinion
Castle BEC @ 7v
Savox 1270tg
RPM Mamba X ESC mount
<iframe class="instagram-media instagram-media-rendered" id="instagram-embed-0" src="https://www.instagram.com/p/BzJzCcxFD1L/embed/?cr=1&v=12&wp=507&rd=http%3A%2F%2Fwww.rccrawler.com&rp=%2Fforum%2Fnewthread.php%3Fdo%3Dpostthread%26f%3D244#%7B%22ci%22%3A0%2C%22os%22%3A328%7D" allowtransparency="true" allowfullscreen="true" data-instgrm-payload-id="instagram-media-payload-0" scrolling="no" style="background: white none repeat scroll 0% 0%; max-width: 540px; width: calc(100% - 2px); border-radius: 3px; border: 1px solid rgb(219, 219, 219); box-shadow: none; display: block; margin: 0px 0px 12px; min-width: 326px; padding: 0px;" height="491" frameborder="0"></iframe>
<script async="" src="//www.instagram.com/embed.js"></script>
Parts List
Max-D SMT10
Drivetrain
MIP Driveshafts
XtraSpeed Axles
Axial front CVD’s
Suspension
SSD trailing arms
SSD front knuckles
Wheels / Tires
Electronics
Castle Mamba X
Castle BEC @ 7v
Savox 1270tg
