Szczerba's 2.2 XTV
You beat the snot out of that rig right out of the gate. Tough truck!
Only way to drive, when in doubt, throttle out. There were 5 courses that day and It got drove hard.
Figured out the Holmes servo issue, just a broken pin, no biggie.
Wheel, tire and foam dress up.
Old school TSS Rockrawler 2.2, 5.5" CI DD foams (med) on some baja claws.
Swapped out the lower shock rod ends for a little longer ones.
Somehow ended up in 2nd place in Class 3 at the RC4WD Scale Challenge in Disney, OK.
Ran the TTC but made a mistake on the tank trap and that knocked me out of a podium spot pretty quick.
Some pictures by RolandRockShop
What about that ridiculous time for first place at KOD?
Surely someone has photos of your crown.
Disney sled pull slow mo.
my favorite part is at the :25 mark you can actually see the variable RPMs that universals create(vs cvds) when turned. #scienceisfun
shows up best on a bigger PC monitor.
<iframe width="853" height="480" src="https://www.youtube.com/embed/IlaXMgo46qo?rel=0" frameborder="0" allowfullscreen></iframe>
So you only running one bec? What voltage do you have it set at? Are you running rx bypasses?
