So, I'm trying to build a pre-runner truck based on the Enduro Trailrunner chassis. If you're curious, I'll be posting updates here:
http://www.rccrawler.com/forum/elem...other-enduro-pre-runner-idea.html#post6106289
I may have made a minor error in my planning though. Because this will not be a crawler but more of a fast trail truck, I opted to use a sensored motor and the relatively cheap (not really a crawler ESC) 10BL120 ESC.
Only issue is that the stock Enduro chassis/stealthX combo runs with the motor 'backwards'. CW rather than typical CCW for the truck to run forwards. I neglected to check whether the 10BL120 can reverse the motor polarity (as per an AXE ESC) and, turns out, it can't.
In a non-sensored rig I'd obviously just swap two of the wires but for sensored, it ain't that simple.
Soooooo, can I just unbolt the whole StealthX assembly from the chassis, flip it 180 degrees and then run it in that orientation instead? Unless I'm being dumb, I think that should reverse the motor polarity making it operate as CCW for 'forwards'.
Only caveate is that the front overdrive will now be on the back (which really really won't work) but I was planning to use some parts from another StealthX to convert the gearbox to 0% overdrive anyway.
Can anyone comment if they think this will work? Thoughts appreciated as I'll want to cancel the order for my motor/ESC if this plan isn't going to fly.
Thanks.
Thanks.
