Spektrum brushless combo review
RudyF6
In a holler on a lake
Horizon last-minute deals got me an AX-24 cheap, perfect candidate for this combo Spektrum Accessories Firma 8A Sensored Brushless ESC / Motor Combo: 1/24 Rock Crawlers | Horizon Hobby when it popped up for under $30.
I was curious how this setup would compare to the 2 Furitek powered rigs I've had for a while.
It's got plenty of power, but no such thing as smooth startup and slow crawl. It stutters so bad at startup you can see the body of the car shake!!
If the AX-24 came out of the box with this setup, I'd be shopping for something to replace it. The twitchy throttle just makes the bouncy little AX JUMP on to its back instead of just flopping over all the time! I thought "sensored" would make it smoother than it is.
I know reviews are about split on this thing, but I had to see for myself.
Glad I didn't bite when it came out, it shows MSRP of $49.99, but I think it was more originally.
I'm kinda' bummed about spending even $30 on it!
Anybody else try this with better results?
That sucks to hear. I personally have no experience with it.
I had seen those on sale a while back. Everything i read about them said not good so I never pulled the trigger. Your experience mirrors what I heard.
Make sure there is no play in the worm gears . If you rotate the wheels back and forth and the drive shaft moves in and out of the axle housing you need to shim it with a larger O ring between the worm gear and bearing that sits in the diff cover. I use the O rings from ball links.
Maybe install the lowest underdrive gears you can find . Mofo has gears that are as low as 53% underdrive.
I'll be doing a u/d in the rear just because it needs it, but the chatter is all electronic. I plugged it in before reassembling the car and I could feel it with the motor/trans/skid in my hand. :confused:
Also make sure the wheel hexes are not binding on the bearings .
That's exactly what it feels like, but smooth as silk beyond startup.
What's bad is you can accelerate through the chatter and back down to a decent slow crawl, but the startup either chatters, spins tires, or flips backwards faster and with more flair than it used to... :ROFLMAO:
I looked at this combo a while back and like others ... never pulled the trigger because of said issue. Would of expected a V2 by now though.
Makes me wonder though, they include a smaller pinion in case the motor runs too hot as-is. (It doesn't)
I wonder if the lower gearing would lessen the effect?
Lower gear ratio would certainly make the startup stutter less noticeable. To get rid of it altogether you might have to go super low at which point you may not get the top speed you want. But if they give you smaller pinion that is an easy place to start.
I wondered if the esc was programmable but looked up on the website link you included and it says it is not programmable.
Thanks for the input guys, this thing is box stock and only 2 packs through it after a once over and all was well.
I think gearing down is going to be the best thing, even axle u/d. I think I have some somewhere. I don't care if it's fast, it's too unstable! :ROFLMAO: But it's fun to watch it crawl!
Good afternoon,
The one I put in was not that bad on startup. It has plenty of power but I did put the smaller gear on from the start (I have bigger tires and weights). Hopefully the gear will help some. Also the factory receiver was causing mine to be jerky so I installed an extra fly sky I had laying around and it fixed that.
Given this esc and motor combo likely sucks ... Horizon has now put it down to 14.99 I picked one up to try it on a rig that currently has 50% UD at both axles I stole the brushed esc from it so its geared down pretty low, for the $15 bucks I will give it a try. As per comments I will use my own RX/TX combo and report back although you will likely not see it around for long. I feel for those who paid the original tag of $99.00.
Yep the gear comes off easy, it is pressed on plastic. I pulled it off by hand, definitely not the amount of torque my revolver pushs in the wraith but still seems like an upgrade to the brushed factory system. More power, slightly higher speed, more reliable (I have burned a dozen different brushed motors in it).
I hear you ... the very first gens of the stock motor were a joke. I mean at 6 bucks a pop ... with the knowledge acquired by now and the amount of available parts/Upgrades I would not even attempt to make a build out of an RTR ... nowadays you can built one that can perform laps around an RTR for just a bit more of the price of the PW and Lexus, which are in the most expensive in the line up.
I have been waiting for Holmes to come out with a brushless micro for this rig. I have half a dozen of his motors and esc's on other rigs and they never die. The lack of reliability in the 1/24 scale electronics is my only real complaint with the size.
