I caved and bought a Hammerjaw when they went on sale for $130. The truck arrived last week and I've had a chance to look it over, and to use it very briefly inside.
The truck is made by HSP, and because of that, it shares a lot of simularities with other vehicles like the Redcat E10 and the Gen7. It's almost identical to the RGT Rock Hammer, though there are some minor differences.
So far, I'm pretty impressed. The truck looks like it will have some definite drawbacks to address, but my overall impression is very positive. The truck is pretty nice overall. The body looks ok, and is narrow to avoid interfering with obstacles or the tires. The interior is pretty nicely detailed, and even has a flat black finish instead of being glossy.
The track width is pretty wide, and the narrow body makes the track width appear even wider.
Quality control on decal positioning is, well, a bit lacking. :lmao:
The axle housings have a newer, more robust design than the Gen7 and RGT Rock Hammer design. The shock & link mounts appear to be very robust, as do the c-hubs up front. The plastics throughout the truck feel very good. They're not soft and flexible like Axial plastics. They don't seem like they will be brittle, but I guess time will tell. Internally the assemblies use the same plastic spools that the E10 comes with, so they will be a definite weak spot. The servo is a ridiculously slow, somewhat torquey metal geared unit, and the steering links are all metal.
The front axle assemblies use dogbone axles and they seem to have a reputation for breaking. I'm not surprised. This close-up shot shows voids in the axle itself.
The axles are my primary source of concern. The plastic spools are a cheap and easy fix. HSP and Redcat sell the 180009 aluminum lockers are plentiful and cheap. The bigger problem is these dogbones. They are apparently fragile, they limit steering angle, and they're hard to get. I'm going to need to source some alternate parts here. There's got to be some dogbones out there that work, but ideally, I'd like to get some Wraith CV axles and an Axial locker. I'll need to dissect my Bomber to see if those will fit.
From the bottom you can see that this utilizes a 4-link suspension with all aluminum links. The center skid is exactly the same as what's in the E10 and Gen7 trucks:
In addition to having the same skid as the E10 and Gen7, it also has the same transmission. Like those trucks, it has plastic gears and no slipper clutch. With these 2.2 tires, that could prove to be another weakness, especially if upgrading to brushless power. Fortunately, Redcat offers metal transmission gears that should be much stronger.
Underneath the body the vehicle uses a twin-vertical-plate setup much like you would see on a solid axle monster truck. The plates are aluminum and they feel really solid.
The layout is pretty well done. The motor & trans are mounted low in the center of the TVPs. The ESC/Receiver is mounted to the rear, and the battery tray is mounted up front where the weight can help with crawling.
The ESC/Receiver combo is pretty basic, but at least the truck utilizes a 3 wire servo, so upgrading that won't be a major hassle. The controller is the same one that comes with the ECX Barrage. It's nothing special, but it's got all of the throttle and steering trim adjustments that you need, and it works just fine. I did find that out of the box, the steering dual rate was all the way up at 100%, which allows the servo to push the wheels past the limitations of the dogbones. This could be one of the reasons that a lot of guys are breaking them so much.
The battery tray is forward mounted, which is nice. It does seem like it's a little high up, but it looks like there's room to move it down slightly.
Overall, I'm really pretty impressed with this truck. It's got it's shortcomings, and some of them, like the front dogbones, may be pretty major. But, I have to be honest, this truck is a lot better built than I expected for $189, and at $130, buying this is a no brainer!
Here's my video review for the truck.
<iframe src="https://www.youtube.com/embed/J9ji39ayzwY" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen="" width="1280" height="720" frameborder="0"></iframe>
The truck is available on Amazon, as well as through Tower Hobbies or directly from Horizon:
https://www.amazon.com/gp/product/B...rc-20&linkId=efaa9ac4cca709d024c4fd84bb244059
