Heynow
I just got the tribute wheels for my SMT10. Did you use the longest offset adaper for both the front and rear wheels?
Did you end up contacting axial about the transmission issue? Curious as to what they would do/say
I have watched your video series via your Reddit posts. I picked up an smt10 at Christmas last year and finally unboxed it yesterday. I went ahead and put in some metal trans gears a castle combo and swapped out the radio to a futaba I thought I had a Bec but must have repurposed it. Anyway. This is all in anticipation of a new event series I'm hoping to participate in this year. Thanks for your builds I'm hoping to slowly bullet proof this one for a 3300kv setup and your series has great info
I wonder what happened to creeperbob. I sure wouldn't mind getting some of his axles for these beasts. I can see those big wheels stressing the axles quite a bit.
I searched the site. It looks like he's gone AWOL a few times over the years. Here's the most recent thread I found about it.
http://www.rccrawler.com/forum/chit-chat/607145-creeperbob.html
I used Vanquish axles and I have no complaints.
The SuperShafty axles should fit like stock and they also already have that round portion ground down to fit axle tubes.
Good lookin trucks soze! Wat size batts u runnin?
Im usin the xtra speed axles as well, but my diffs are lock. Runnin stock axle shafts, without issue so far, on 4s. Traxxas mxl6s esc (castle version) with a tacon 2400kv on 14t/54t gears
Sent from my SM-J327VPP using Tapatalk
Ill do a build thread for my rig eventually.. i put a crazy amount of time setting my SMT10 up. Of everything i have, its my favorite.
Some reviews of it said that the tangs were too long and interfered with the open diffs? Did you have to grind it down? I already have to grind down whatever axles have a large ring after the tangs, because I'm using axle tubes. The only reason I'm using Boom Racing axles right now is because they fit the tubes.
