Solitaire
I've been running an original SuckerPunch for a couple of seasons now on AX10 axles with CreationFab extensions and XR mod. Truck has worked well and has never given me any grief.
When Chris and Dan took over 5th Dimension, they offered various colors and an improved chassis and skid. I saw the red one and had to have it.
So, another build is underway. This time I thought I'd try the AR60 axles mainly due to wanting to get the servo mounted lower and a bit more protected. I also have a Hulksta tranny I got for the first build, but never installed it.
So here's the obligatory parts list...
5th Dimension Chassis in red
AR60 axles
Brass Brute tubes for the front axle made by one of the guys in our club
Red VP knuckles (found a pair in China)
Locked Up's FI spool for the front
Holmes Hobbies Crawlmaster spool for the rear
Holmes Puller 400 16T with large wire fill
Axial over/under diff gears
Axial universals shaved for more steering
Stock Axial rear axle shaft (Hopefully CreeperBob Ti soon)
Hulksta CF tranny with stock XR gears
DLux front and rear CF link mounts and servo rack
DLux 3/16" lower Ti links with Ti link sliders
Fifth Dimension 1/8" Ti upper links
Fifth Dimension 3/16" Ti tie rod
Savox 1283SG servo
Holmes BR mini/CCBEC smashed
SCX10 alum shocks w/DLux no-preload spring cups
Axial WB8 driveshafts shortened with inserts
Crawling Calvins steering arms
RCBros knuckle weight system
Lattice Innovations shift hubs
Rowdy Racing front battery mount
DIY Lexan electronics plate
Gunnar's body mounts
Gold VooDoo's on unknown CF wheels
More pics in a day or two.
AR60 axles
Savox 1283SG servo
