I'm no machinist. How many flutes should I be using?
I dont claim to be either but I prefer a 4 flute on 7075.
Softer AL I do go to the 2 flute.
Judging by your chip size on the 7075 cases the 4FL, while not ideal, is serving you fine. Most speed, feed and EM geometry recommendations are made for CNC machines pushing much harder than you ...
I could expand but...
Plastic cutting EM's need to be the sharpest of the bunch. Don't use them to cut metals.
Judging by your chip size on the 7075 cases the 4FL, while not ideal, is serving you fine. Most speed, feed and EM geometry recommendations are made for CNC machines pushing much harder than you are.
Can you engage your lathe carriage to act as a power feed while you are milling?
My mindset is always pushing the equipment almost as hard as possible, so that's probably why I've got two flute on the brain :ror:6063, yucky stuff. It's so gummy
6061 cuts just as horribly, like bubble gum.
Other than the brush hood, what is your concern with the motors? I know its way against the normal thinking but I have not run any type of motor protection in about 2yrs(?). I have not noticed any problems or issues other than some scratches that easily buff out on the cans. For the brush hoods, maybe John can hook you up with the reverse spring mod like EddieO does for me? Keeps everything nice and out of the way.
I do have plenty of old Epic motors here we could scrap the hoods from, might as well do something to make old parts useful. The only hitch is that somebody bought all my reverse springs, and the hoods are all laydown style which is too wide for 5 slot comms.
At that point might as well just integrate the guard into a sub hood plate, it would be about the same effort as cobbling things together with parts that are no longer available.
