islandlife
Hey folks, im having some trouble with the servo setup in used trx4 i picked up.
The truck is a stock trx4 sport, with a 35kg amazon servo. The esc motor i have running off a 1500mah 3s. The servo has its own 900mah 2s.
The signal wire from the servo goes to the rx, the ground is connected to the servo, rx and 2s lipo, and the positive wire goes from 2s lipo to servo.
Is this an acceptable way to wire this setup?
The issue im having is the steering will flutter left/right with no steering input. If there is resistance or steering input from the transmitter the flutter *usually* goes away. Other than that the truck runs and steers fine.
Thanks in advance for any insight.
