Fordfreak95
Your gonna need a hardened pinion gear to match the RR spur so get a 16 and a 17 and see which one you like. That RR spur will bust teeth off axial pinion gears. And Losi pinions. How do I know...guess!
Put the RR in last night. To get it to move w/o slipping I have to tighten it down so hard the truck barely rolls. I haven't been able to test much due to rain. The YXL is not indoor friendly. I'll test more when I can get it outside.
Same here I ended up going back to stock slipper. The RR slipper woulod slip TONS even with the nut full tight.
I want to do this mod, but I'm trying to wrap my head around the impact of going from a 68t spur to the 64t spur of the Robinson Racing slipper. Currently I run 68t spur and 17t pinion on 4s. My gear ratio is 4.00. Going to 64t spur to 17t pinon the gear ratio would be 3.76. Could that cause the motor to overheat? Drop torque? These numbers seem small and don't seem like they would make much difference. However, when I went from a 17t from the stock 15t pinion, the speed increase was very noticeable to me. With the 68t and 17t pinion, I'm really happy with the torque and speed of the vehicle.
Motor temps for me after hard driving are around 130 and 140 after "I just stole this Yeti XL" driving.
If you want to keep the same gear ratio when you switch to the 64t spur just use a 16t pinion. That will give you the same 4.00 gear ratio as before.
