Farmer
Sold my old rig last year, but I'm back now!!! First off huge thanks to Rick at SuperShafty, John at Holmes Hobbies, Ryan at BC Paints, Bruce at BmachineRC, Jake/binary terror, and Ben/Superduty03. If it wasn't for your guys support and help this rig wouldn't be possible"thumbsup"
Had a double agent I intended to use, but built and drove a berg axled Remedy for a good friend and loved it!!! Been driving bodied for awhile and felt like going back. Even though Ryan at BC Paints hooked me up with a sick scratch art Nightmare Before Christmas body Ok on to the goods..............
Front axle:
-Dlux case with 7075 center
-milled gears with, CKRC 3rd, and Mann 2nd.
-Super 300 HD's
-RC Bros tubes
-RC Bros hangers and knuckles weights 1.85 oz of weight
-Vanquish c's and wraith knuckles
-Tamiya king pins and traxxas Teflon washers between c and knuckle
-Shift hubs
-Dlux upper link mount
-Futaba BLS172SV
-3/16 TI tie rod
-3/16" AL 7075 drag link
-E Bay Robo horn
-Holmes Hobbies 37 turn big wire 400 puller, 13 tooth pinion
-music wire for hex pin
Rear axle:
-milled gears, CKRC 3rd, and Mann 2nd
-RC Bros tubes
-Hulksta TI shafts
-Shift hubs
-MFAV rear upper link mount
-Holmes Hobbies 37 turn big wire 400 puller, 12 tooth pinion
Chassis:
-BmachineRC Remedy
-3/16"AL 7075 solid uppers
-BmachineRC 3/16" TI lower
-RC Bros shock bodies, spring retainers, pre load collars, springs, and shock caps modded by me.
-Axiak scx 10 shock shafts, machined piston, and rod ends.
-22.5 weight in front and 27.5 in rear
Wheels and Tires:
-Y-Town cf 2 piece wheels .8 wide with 3/16" AL 7075 spacers
-CI 6" narrow with soft outers in front and medium in rear
- narrowed and clocked silver Voodoos by binaryterror
Electronics:
-Holmes Hobbies BR mini's water proofed
-CC bec water proofed set at 7.4
-Futaba R614FF decased and water proofed
-Max Amps 430 mah 4 cells or Cheap Battery Packs.com 450 mah 4 cells
That's the run down for now, just waiting on shock springs and some more knuckle weight. Once I have those in hand I can get it all buttoned up"thumbsup"
Super excited to be back and glad that vendors like Eric at Dlux Fab and William at RC Bros are keeping the Berg alive!!!!!!!!!!!!!!!!
Front axle:
-Super 300 HD's
-RC Bros tubes
-Shift hubs
-Futaba BLS172SV
-3/16 TI tie rod
-E Bay Robo horn
Rear axle:
-RC Bros tubes
-Hulksta TI shafts
-Shift hubs
Chassis:
-BmachineRC Remedy
Wheels and Tires:
Electronics:
