Losi calls the Micro Rock Crawler McRC
and the Trail Trekker Mc4x4 so i figure
the Redcat Sumo Micro Crawler = RSMC
so far its the same 7mm hex. losi wheels and BWD/crawler X hex wideners fit fine. though the barrel nuts do NOT. if you want to use them you will need to find barrel nuts with a thicker thread.
since the crawler X wideners are plastic you might be able to force the barrel not on and recut the threads inside
the ball ends and cups for the rod ends fit so that means the axles will bolt right up to your links as well as the shocks
the stub shaft has lots of thread on it which is great if you want to go even wider. though it's thicker and uses a larger wheel nut than the losi micro. however the stock wheel nuts are metal locknuts already.
here is the axle without Mc4x4 double thick hexes on the left and with the Mc4xx hex on the right.
as you can see with the Mc4x4 hex it takes up all the extra threading
redcat axles measure out to 104mm outside of tire to tire. 79mm from the flat side of the hub to the other
the axles have a spool diff not worm gears ( YAY! )
the male end of the losi driveshaft fits nicely in the female end of the sumo micro crawler (RSMC ) though oddly the losi female end wont fit with the male RSMC driveshaft.
the U joints appear to be the same size though i haven't taken them apart and tried to get them together
the RSMC doesn't come with any tools, but that's ok for the price.
the radio feels cheap, but so far works fine. again for the price any kit radio would feel cheap.
the motor and trans setup is interesting. they use a micro geared motor much like the polu motors. but its in a BIG plastic housing that the ESC/RX mounts to with more gear reduction inside
the servo looks like the cheap $5 servos you find on ebay or hobby king. plastic gears inside. I do like the slim servo horn
the bent links and rod ends are short but look decent
the tires and wheels are a hair wider than the McRC but you barely notice. tire height is in between a McRC and the taller Mc4x4.
Im not sure if losi tires fit on the RSMC wheels but honestly Im sure most people will swap both wheels and tires anyway.
I really like it so far though ditching the AAA batteries is a must. it just doesnt have enough power to get even out of a mild bind with AAA's. the RSMC would LOVE a lipo
Sorry for the crappy pix, i just took these with my phone
the gear motor and trans setup.
the motor is similar to the pololu gear motor
from left to right. the top end of the wheels on the axles were lined up flat against a straight edge so what you see is the TOTAL difference in width on the bottom side
RSMC with Trekker ( MC4x4 ) hexes
Mc4x4 with BWD wideners (McRC axles are the same as Mc4X4 just without the longer stub shaft and thicker hex)
RSMC stock width
McRC with BWD wideners
McRC with CrawlerX wideners
McRC stock
so it seems the RSMC is the widest followed by McRC with BWD wideners. I dont have a Mc4x4 But Im sure the trail trekker is no wider than the BWD
also a side note. because the RSMC stub shaft is thicker BWD and crawler X barrel nuts wont fit. you could possibly find the correct barrel nuts or maybe use the Mc4x4 extended hex?
tire height is in between the McRC and the taller Mc4x4.
I haven't taken apart the axles yet but this is the parts explosion it came with
center trans gears
axle
Ok it seems Photobucket unflipped the pictures, you'll have to deal with it
here are some pictures under popular bodies to give you an idea of scale
RSMC axle under the popular JK body
Losi micro axles
Lindberg 1/20 Toyota
Front axles RSMC if you look close you can see the McRC axles under the rear
Someone asked for pictures of the link and shock mounts
if you swap the knuckles left to right you can move the shock mounts forward which may help in some scale builds
Servo removed. I like the servo saver and link. just a little longer and its perfect for a chassis mounted servo
LMcRC with lockouts on the left RSMC on the right
McRC left RSMC right.
RSMC springs seem a little more stiff than the McRC but the shafts should be more durable
here you see one of the many axle bushings. Im not sure if the McRC bearings will swap over.
The outer RSMC shaft mates up perfectly with the McRC inner shaft. the "splines" or hex cut ends are not the same between the axles.
Knuckle, the 2 sizes of bushings and the silver McRC inner shaft above the black RSMC shaft
I forgot to write it down but Im pretty sure the pinion is 13 tooth the ring gear is 24
the housing seems pretty thin. it should hold up to normal use but I wouldn't mind a stronger case and metal diff gears
Got everything back together and moved the steering behind the axle
Plenty of clearance once you mount the bar below the knuckles
even at full lock, though you may have to be careful with your lower links
stub shaft pix. note the RSMC stub shaft has thicker threads and needs larger wheel nuts.
the shafts are the same thickness so they should all be able to swap around
left to right
McRC
Mc4x4
RSMC
this picture shows the stock wheel hex on the left and the Mc4x4 double thick wheel hex on the right. its a little hard to notice but take note of how far the beadlock nuts are from the steering knucle
RSMC stock width
McRC stock
center trans gears
axle
Losi micro axles
left to right
McRC
Mc4x4
RSMC
