Pics added 7/18.
I have been hesitant to start this thread because I have no means of taking pictures and proving what I say. I have been tinkering with my Redcat Rx10's steering for 3 years now. Here are some of my actual experiences and opinions based on experiments I have tried. I'll start with knuckles...
Anything that fits an Axial AX10 will work with the right washer in the right place. It should always be a "high steering" knuckle so that you don't bump into the axle and limit your steering potential. The more you spend the better it gets. This hasn't been true with all areas of my Redcat testing, but knuckles is the place you can really tell a difference with each step up.
Here's your entry level step up.
Hot Racing High Clearance Steering Knuckles Aluminum for Axial AX10, SCP21M01
These are way better than stock and have the high clearance aspect you need for good steering on a Redcat. Do you see the way there's that bend in the steering arm when it comes off the knuckle? This is less than ideal and causes some minor issues. It is stuff that would only matter if you were going for the guiness book of records worlds best turning Redcat like I happen to be. The other minor issue with these is that (I think) they are 8* knuckles. This causes there to be some pinching of the Chub at extreme angles. Once again only something that matters if you want ALL the turning. Overall I give them a "B" when I factor in cost vs benefit. They are a solid alternative and will definitely get you started down the right path.
Your step up...
RC Accessories - Axial SCX10 Parts - High Steering Knuckles - Vanquish Products
Now these mamba jammas are all you really need. If you have any interest in these, I'd snap some up just in case Vanquish ever goes all Zno on us and bails. See how the arm comes off straight? This gives me all the steering and makes it so that my knuckle is never the thing holding me back when I am looking for more. They are also 0 Ackerman, so there is no pinching to limit me either. I paid $42 at my LHS and still give them an "A".
The Mack Daddy be all end all gods gift to Redcat steering....
DLUX FAB | products
I got these in the aluminum because they match with this stainless steel chrome plated axle I have been working on. I got them a month ago and they still give me wood every time I walk by my crawler. The two extra bearings he puts in these, coupled with all of the holes and mounting options ...well anyways I like em. "A+++"
I wish I could take pictures here, because I do have one durability concern. I reeaally have that carbon fiber stretched out. I'm pretty sure I wasn't supposed to use the mounting holes quite the way I did, and only have 2 screws holding each carbon fiber plate on instead of a potential 4. Technically, he is only using 2 in the picture, but they are at that nice diagonal pattern. So we will see how that goes. If it ever failed I wouldn't hesitate to replace it with some type of metal and still think they were the cats meow when it comes to getting more steering in a Redcat.
Someday I will step up and get some of the matching wheel weights, but I have no issues with tinkering on this thing for another 3 years. So it's no hurry.
I'll do a post on Wheel wideners later. I will do one on Axles as well. This is an open source discussion and any one is welcome to talk about after market parts that they have used to enhance Redcat Steering.
Your step up...
DLUX FAB | products
