Receiver/Electronic Issues Newb
Kromlech
Oneonta
Okay, so to start things off I'm new to the 1:10 scale rc world and hobby-level trucks. I picked up an Everest 10 from Redcat and that became my kids' truck soon after I picked up a Gen 8 and more recently the Blackout sc pro (which has been super f-ing fun). I have upgraded and modded both the Everest and Gen 8. I've always been a fan of tinkering with things, but electronics maybe aren't my strong suit. I just put a Holmes Hobbies Torquemaster Expert 550 27T motor, I run a Hobbywing WP 1080 ESC on a 3s LiPo setup and the standard Redcat controller and receiver for now. After installing my motor it seems like I'm not getting any power to the receiver. I tried the receiver in my other truck just to check the receiver and it does still turn on in that truck. Everything was running fine before I swapped the motor, that's the only thing I've changed since I was running it the other day. I managed to get through 2 batteries trailing. Could really use some newbie tips if anyone has a clue what's up. Thank you.
WELCOME TO THE FORUMS!!!!
What voltage is the out put of the HW1080 BEC set to?
What TX/RX are you running, and what is the max rated voltage for the RX?
Just a guess here... But, it sounds like you have your ESC's BEC set 7.4VDC, and the RX cannot handle that much voltage.
I set it up before I ran it the first time, had the lower voltage set for the servo. Everything was fine since I swapped the ESC a couple weeks ago, did a bunch of trailing on the stock motor and just set up the new HH motor. Turns on, gives me the 3s LiPo beeps and then the led flashes red on the ESC. The receiver is the stock r3e and stock redcat controller. Batteries are all good and I tried the receiver in the other truck to see if it was shot. Light comes on and controller works on that one. Light isn't coming on the receiver on the Scout, seems to not be getting any power at all. Haven't changed any settings in the ESC, fresh charged LiPo. Its been a hell of a curve learning all this. Everything has gone alright, or I've gotten past everything else so far.
Yeah, that's what I was saying, trying to say. The RX works in another truck with the another HW 1080 ESC. Light on the RX comes on when I turn that truck on, not on the Scout. Only thing I changed was the motor since it was running last.
You did not answer the question. What voltage do you have the 1080 BEC set to? If we are to be of any help you need to provide specific information.
Sorry, internal BEC is set to 6v, I've done some messing around with it. I have the TX/RX working and steering. I've been on the go today with just a few minutes here and there. Going to try swapping the motor connections around when I get the chance in a couple hours. Rebound the TX/RX went into the ESC calibration and it won't get past neutral set. From what I've read it may be just swapping the wires around from the ESC to the motor, I really hope so. Will keep people posted. Thanks for input. Really been wracking my head around this one.
It is, just got home for the night to tinker. Going to try swapping the motor connections, watched some videos, some people are saying I might just need to switch them.
Edit: Swapped the connections, still can't calibrate. Still no forward or reverse. I'm at a loss, new Holmes hobbies motor with no go.
