RcBros Front and Rear Berg Tubes
Rear tubes, including protos for DLux shafts are done. Once we get back from Easter jeep safari these will be available.
so if I get these tubes, and vanquish c hubs, and vanquish knuckles, what axle shafts do I use? Stock dogbone and outdrive? Will that work? Are there some drop in cvd's available? I'm not into the custom made stuff. When something breaks I want to be able to buy another and put it right in. Can this be done?
Thanks.
The short answer is no, not the stock axles.
Check out Will's post #18 in this thread,he says SDS300 HD or the Dlux shafts.
Good luck finding the SDS's he has not posted in quit a while.
The Dlux shafts have a large tang on them and come with a locker to fit them,
and are very strong. They are made to allow up to 70 degrees of steering,more
than most setups can use. I have Erik's shafts in my berg and they work very
well IMO.
Good luck in your quest : Mike
Rear tubes are in stock and shipping after we get back from moab. I'm looking for two testers for the Dlux shaft versions. PM me with why you deserve them. My requirements are you must have a good camera and provide real feedback.
Prices Have Been Slashed, come check out the sale!
We also have custom Offset truely center super tubes putting your supers at 13.5" with with a flat faced wheel and Zero Scrub "thumbsup" PM for details.
Also 7980 Servo Mounts for the super tubes!
I believe they are VP berg universals. They may have been discontinued. I'm not 100% sure, they came with the berg axle I purchased used. They fit great with axial ax-10 chub and VP high steer knuckle. The inner bearing is square with the axle tube.
