Honeyman108
Hey Folks here we have my project of the year my TRX4 Honey Comp Crawler Build I have done so much to this rig and still have plenty left to go and hope to finish before years end but its already extremely capable and quiet also its building its character with all the body modifications left to go most of the parts will be mentioned and will provide photos of this great truck!
Im using the Flysky GT5 6 channel and its insane the best controller period simple very versatile and crawler responsive on torque....
Brands used on the build as follows:
Hot Racing (All Housings & All mounts & All links & All Posts & Alll Spacers & Most Gears & Accessories and the Front battery tray)
Yeah Racing (Brass Wheel Hexes & Alloy Axle Housings & Portal Gears)
Samix (Titanium Links & Servo Horn)
Holmes Hobbies (ESC & Motors & Bypass adapters)
Reefs Rc (Servos & Grease)
Proline (Tires & Bodies)
GearHead (Wheels & Lights & Cables)
Holmes Hobbies Custom Pro 20 t motor
Holmes Hobbies BR-XL ESC (Next install)
Reefs RC 777 servo (Next install)
Hot Racing (all around)(overdrive gear in front & stock in back)(driveshafts)(shocks) (Frame Bumper Mount)
Yeah Racing (diff covers and brass wheel hexes & steel portal gears & Axle Housings)
Samix Traxxas TRX-4 312mm Titanium High Clearance Link Set (10)
GearHead Ez lock trail king Wheels (Installing gearhead black 12pack ezlock wheels)
GearHead Six Shooter and TrailPod LED's (THANKS RPP Hobby YOU BEES BUZZZZ)
Wertymade stubby chino edition bumper
DSM off road (bungee hook clamp)
ST Racing Concepts Traxxas TRX-4 Aluminum Rear Bumper Eliminating Brace (Silver)
Proline Hyrax and Super Swamper Tires
Traxxas 8062 Axle Shaft Front Heavy Duty Portal Drive Input Gear Left & Right
Traxxas 8061 Axle Shaft Rear Heavy Duty Portal Drive Input Gear Rear Left & Right
Apex RC Products RC Remote Electronic AUX Channel On/Off Switch #9025
All Body Mods used Hot Racing Parts and Hardware.
As you can see in the photos the truck is going through a couple of transformations this year as far as upgrades left and currently finishing are the Axle housings the ESC and Servo as well as lights and another body questions comments suggestions!
Right now this Rig with the Hobbywing QuicRun 1080 and the Holmes Custom Pro 540 20T motor and the front hot racing overdrive beveled diff gear and steel portal shafts and the Reefs Raw 500 Servo this thing really gets through most rocky situations so I can't imagine what it will do when I switch to the Holmes BR-XL ESC and the Reefs 777 14volt servo and the beveled stock diff gear in the back well ill make another video after the build thread goes up so on and on we build and Buzzzzzz....... Aloha.....
