RC4WD Lightened Gear Set for Enroute Berg Axle
Rckcrwlr
Here
Complete Gear set for an Enroute Berg axle. Built to be lightweight and strong. This is a Hardened steel gear set and has been fully field tested and approved by top drivers. Built for durability.
Specifications:
Full Complete gear set to upgrade 1 axle
Hardened steel gears for superior durability
CNC Machined
Lightened to reduce weight
New Lightened Units 1.85oz (52g)
Original Stock Gears 2.11oz (60g)
What's Included:
1x Lightened Gear Set for Enroute Berg Axle
1x Drive Hub
1x 48t Main Gear
1x 42t Medium Gear w/12t Small Gear
1x 40t Small Gear w/14t Small Gear
4x M3 X 4mm FHSC
2x Pins
Note:
For complete truck, you will need to order two of this item.
Cool, didn't see this coming. "thumbsup"
Do these use metric pinions like stock or standard pitch?
And how about that?!:shock:
Bergs really are coming up again!!!
Correct me if I'm wrong but RC4WD normally make tough gears, at least the bully ones are great!
And 50$ for a full set is nice!
How about RC4WD making a new bully axle?! 'bout time!!!:flipoff:
x2 on a new Bully axle.
And in the mean time please do make a lw gear set for the XR10 as well.
I believe they are stock...
How long until these are in stock?
Subscribe to the notification for when they come in stock...I would guess a couple weeks.
These are the same material as the Bully, XR10 and AX3 2 Speed Gears...so yes they are tough. 53Willys and theinfidel have been beating on them for a long time...
If your Bully's are Old and you want new ones...you can buy new cases to make them look new????
X2
Sent from my GT-I9300 using Tapatalk 2
Glad you guys like them...
So any chance of RC4WD doing LW versions of their XR gears off the shelf also?
Very cool, I was hoping these would be coming out......but mine dont have the fancy speed holes:cry: Lmao!!
Glad to see the locker is included, that will eliminate any confusion with the old styles floating around.
This is fairly of the original topic, and in the wrong section.
I for one am keen for these gears, I know how strong the xr and the bully gears are, can't wait to try them in a berg."thumbsup"
Couple shots of my test gears, these were unlightened.
No grease = new
greased = around 25 packs run or so, no appreciable wear yet.
Doesnt the slot in the locker, on the longer side need to be deeper???
if i rember corectly that was a big complaint when enroute switched from the black lockers to the silver ones.....
some axles didnt go deep enough into the slot....
I had this problem when I went to install them, and had to dig out an old locker that was deeper cut. The silver ones pictured fit the SDS axles, the proto locker did not.
