Ranch Muffler Jeep
After I confirmed the dimensions were acceptable I began adding plates one at a time until the full blade was complete.
The bottom plate had to have holes to install the hardware for the winch through the bottom.
The next step was to fill the corners, then weld and grind the complete blade. I use a cheesy clamp system to hold it while I weld it up....
Absolutely stunning! I cant get over how clean it looks. I tried to do the same thing with braze but the heat required is rediculous. Ive got to precut and bend all the corners together then braze. I guess i could try your method but without welding since i dont have a welder.
Thanks guys!!!!
After the main blade was completed, I had to make the tubes to match. I selected 5/32 solid rod from the local Hobby Town. I am using a Rigid brand bender to make the bends....
It was tough to make the winch fit in the center of the bumper and make the tubes fit properly. The tolerances are very tight.....
I had to put the light tabs on the top tube to hold the axial light buckets in chrome. I wasnt to pleased about doing this, as I knew they would likely be ripped off during a rollover. I guess you dont roll the 1 to 1's too often :)
Awesome job on the Jeep!"thumbsup" I saw this same rig in the Dec. issue of RCCA. I was planning on doing a Jeep myself after reading the article. I was just curious how much you would charge for a set of those bumpers?
WOW:shock:! That is some beautiful metal work, nicely done"thumbsup". Looking forward to seeing some more.
This is awesome!
I too first saw this in the December RC Car Action issue. I was blown away and inspired. I have always loved seeing the amount of detail people put into their scale rigs and I am now setting aside money to buy an SCX10 and do one myself.
I have no welding skills, so my bumpers will have to be the buy and bolt on type. I believe I will have a hard time finding a swing out spare tire carrier from a company like Pro-Line.
