R1 Mods, Tips and tricks
cytogen
Port Coquitlam, BC
I just wanted to put together a consolidated thread that lists all the common mods, tips and tricks to keep your R1 alive and well. This will just be a series of links to various threads that the author as performed. Consider it a one stop shop for all the common mods.
If you have any mods that should be added, please let me know and I'll add them in.
Chassis
Front electronic tray by cytogen
Battery tray modded for a front electronic tray
Suspension
http://www.rccrawler.com/forum/g-made-crawlers/433998-more-articulation.html
Looking for more flex?
http://www.rccrawler.com/forum/g-made-crawlers/435981-gmade-r1-stealth-cantilever-suspension.html by bikerzee24
Stealth Cantilever suspension
http://www.rccrawler.com/forum/g-made-crawlers/462435-piggyback-soft-springs.html
Spring alternative for the XD Shock series (103mm)
Drivetrain
RC4WD R2 Dig Install In Stealth Chassis by bikerzee24
RC4WD R2 Dig Install In R1 Chassis by supermoturd
Wraith trans install In R1 Chassis by cytogen
Another Wraith Transmission Install by supermoturd
Portal Axles
http://www.rccrawler.com/forum/g-made-crawlers/449324-r1-knuckle-mod.html by offroadace
Increased steering angle with R1 aluminium Knuckles.
http://www.rccrawler.com/forum/g-made-crawlers/321442-szczerbas-jk-minus-some-doors.html#post3155517 by Szczerba
Increased steering angle with TLT knuckles and CVDs.
http://www.rccrawler.com/forum/g-made-crawlers/422913-gmade-r1-axle-shaft-xvd-mod.html by offroadace
Adapting RC4WD XVDs to fit R1 aluminium Knuckles
http://www.rccrawler.com/forum/g-made-crawlers/435290-gmade-shafts-alternative-fix-pic-heavy.html by Syncrog60
Modding an CR-01 driveshaft doggone to fit the portal gears
http://www.rccrawler.com/forum/g-made-crawlers/355908-gmade-r1-bearings.html
Alternative bearings for R1 portal axles
http://www.rccrawler.com/forum/g-made-crawlers/492761-reducing-backlash-slop-drivetrain.html by supermoturd
http://www.rccrawler.com/forum/g-made-crawlers/492666-r1-steering-revisited.html by supermoturd
Looking for increased steering angles?
http://www.rccrawler.com/forum/g-made-crawlers/494709-underdrive-r1-finally.html by supermoturd
http://www.rccrawler.com/forum/g-made-crawlers/495412-poor-mans-hd-locker.html by cytogen
Has anyone stumbled upon a protective roll-bar for the R1 to protect the optional 3-light array on top of the roof?
I just ended up mounting my upside down so it was taking up the "windshield" area. Not really scale looking, but at least it protects the aluminum light buckets from getting dinged up.
Just for the record, since I've been using my modded CR01 dog bones running a 35t motor on 3s I haven't had a single issue.
Pretty pleased with that. "thumbsup"
For Sale section? Might want to search there first. It's been a while since I've seen anything for R1 though, let alone an RTR since they are sold as kits.
You could also post in the Wanted section what you are looking for and see if anyone responds.
Google , rtr and kits available
ya...it seems like ARTR are the only things around at the moment... kinda sucks but... anywats thanks for the info and I'll keep an eye out...
Old question: But I sell/Trade mine. In parts now waiting to add upgrades I purchased, Digs, Aluminum mounts, Delrin skid etc...
The R1 never came as a RTR. If that is what you are looking for, you'll have to scour the classifieds for a used one that someone else has built up.
I know its slow over here, but I wanted to say thanks for all the info you guys have posted over the years. Im getting started on my own set of R1 axles soon and im going to rely heavily on what ive read here - thanks again guys!
Whats everyone do for 12mm wheel hex's ?? Cant find stock ones anywhere, and don't know pin size !! Wheres a good source for R1 parts in the US ??? :x
