Pre-Order Tamiya Toyota Hilux High Lift 4x4 3 speed Kit
EeePee
MODERATOR™
Moderator
Ohio
Pre-Order the Tamiya Toyota Hilux High Lift 4x4 3 speed kit
Combining nostalgic feel with modern mechanics, the superbly detailed classic Toyota pick-up truck body is now mounted on the same chassis as the Ford F-350 High-Lift.
About the Model
Durable ladder frame chassis features steel channel and resin crossmembers for high strength.
Adjustable front and rear leaf spring suspension system equipped with friction dampers.
3-speed transmission allows gear changing and realistic low-speed driving.
Propeller shafts and slipper clutch efficiently transfer power to all wheels on any type of terrain.
Differential may be easily locked in place to enable improved off-road performance.
Highly-detailed injection-molded body complete with new parts for rear bumper, muffler, side steps, side mirrors, and wipers, accurately reproduces the classic pick-up truck.
Manufacturer logos depicted with metal transfer stickers, and various metal plated parts accentuate the truck's body.
Quick-access battery compartment enables easy battery changes without removing body.
Includes type 540 motor.
4-channel transmitter, ESC, and running battery & charger are all separately required.
Installing the separately available Pick-Up Truck Multi-Function Unit MFC-02 (ITEM 53957) will further enhance the truck and put a wide range of realistic light, sound, and vibration effects at your fingertips.
ELECTRIC KITS REQUIRE:
(unless stated differently above)
Radio: 2-Channel with servo(s)
Battery: 6-cell flat with standard Tamiya connector
Charger: AC/DC timed or peak for 6-cell battery
Paint: PS for Polycarbonate/TS for ABS
Misc. Items: Building and track equipment
$379.99
[SIZE="7"]www.tcscrawlers.com[/SIZE]
"thumbsup"
