david37370
hello!
as i understood it from reading, clod stall happens in MOA rigs when one set of wheels (front wheels or rear wheels) are in less tractions with the ground, and need less force to rotate, and then the other motor under pressure doesn't move until you throttle more, and instead the free wheels/motor will move.
I have read also fixes for it that say i can balance it with different pinions, or 2 ESC's and batterys, and other things, but i thught about it a little and a brilliant thought came: maybe connect the axles with an universal shaft (like the driveshaft)?
after all that is the disadvantage of MOA's against shafty's! the shaft driven cars rotate all the wheels at the same time, because of the shaft. that is very good cause then the power will ALWAYS go to the most pressured axle, and wheel. but what with the torque twist..?
the shaft im talking about will connect both the axles to each other, and have the power on the most pressured wheel, also it will will lower the COG because of the low motor on axle, and no cons! so far... hehe
what do you think guys? after all im 15 yrs old maybe i oversaw something...
by the way im waiting for the rs10 to come.. 2 days now..
